Hi Everyone - first off let me start by saying that I just got an Mbox 3 Pro - I'm building my first studio so I'm really noob when it comes to this stuff specifically..but don't get me wrong, I own a computer repair company and I'm very tech savvy - so the first thing I did when my brand new Mbox pro 3 didn't power up is google it up and was ultimately directed to this thread: http://duc.avid.com/showthread.php?t=288537
Long story short, I went balls out and took matters into my own hands rather than dealing with returning/waiting/BSing with CS to possibly get another bad unit...... I opened my new MBOX - now I didn't know where to start so I took every single knob and screw out before discovering the whole thing slides out with just 4 screws that are hidden under the rubber feet on the bottom of the unit. (Image below) crap is there no image posting on this forum?? http://img403.imageshack.us/img403/7061/60389858.jpg SO, moving on...there ended up being an IDE like looking cable that was totally unhooked!! (See pic below) I plugged it in, plugged in the power, and low and behold, (7 seconds after hitting the power switch) I HAD POWER! http://img811.imageshack.us/img811/6154/85786064.jpg Please keep in mind that I had to do some bending of the 2 plates to be able to fit my fingers in there to push one end in, and used a regular sized flathead to push the other end in - be careful with the flathead, you don't want to hit/touch ANY of the components in there. Here is a pic of the back plate....there are 2 kinds of screws that hold everything together, I'm not sure that you need to take any of them out to do this but in case you do, I've circled the 5 screws that are different than all of the other ones so you know what goes where when you put the unit back together. http://img89.imageshack.us/img89/5631/76177594.jpg Hit the power switch and give it a few seconds, if it powers on, grab your blue moon and cheers who ever is closest to you! A few important points:
Nicely done
Gigabyte X79/intel i7 3930K, 32GB RAM, Presonus Studio 1810C https://www.facebook.com/search/top/...0sound%20works I started in this business with nothing..........and I have most of it left ![]() BTW, my name is Dave, but most people call me.........................Dave |
Excellent post.
Could have come loose due to shipping. But it also could have been poor manufacturing QC.
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
Thanks for this, i had the same issue, opened up the Mbox Pro 3, and the cable in mine was disconnected as well. Re-seated the cable and voila, it worked. I'm in west africa and the nearest avid rep is a long way away :)
It Worked!!! I unscrewed the four screws hidden behind the cushy pads (took abit of force) and voila! There has the unstuck cable, same as your pic...Took a few small fingers and a long object to stick it back in place!
You..are..a....genius. I suggest you try this if you have NO power to your mbox 3 pro at all. ![]() ![]() |
hey nstabl great work, here i am dealing with an mbox 3 pro too, but my problem it is that the reverb does not sound, i do the normal routing, but still dead, inside the box can you recognize where it's the reverb? i am waiting for open the box for the warranty so if you can help me with that it would apreciate a lot.
thanks ! |
![]() Quote:
Sounds like a bit of an oversight on the assembly line, possibly due to the fact that previous versions didn't need a power supply and someone forgot to tell the assembly techs that these new versions need the power supply connected
![]() Good for your for finding the fix. I am sure it will save a lot of people wasted time in sending units back. |
![]() Quote:
DIY I guess..No power on your new Mbox Pro 3? I fixed it!!! | nstabl | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-07-2011 12:01 PM |
DIY I guess..No power on your new Mbox Pro 3? I fixed it!!! | nstabl | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-20-2011 03:39 PM |
Re: Is the Power Harness Issue Fixed? | blizzard | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 03-07-2007 08:57 AM |
so... i guess i have a bad power harnass | 16yearsjeff | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 02-25-2005 08:03 PM |
new "mbox" not too far away, I guess | Blutus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-30-2004 05:34 AM |
