Apple Keyboard on Windows 7
I just hooked up my apple keyboard to my windows 7 machine and it was super easy. I haven't installed pro tools on this new computer yet, however i was wondering if you think the key commands will work in pro tools? I'm still waiting for my PT9 purchase to arrive in the mail. **keep in mind i am very very used to pro tools on a mac and am scared that the key commands will be different - mainly with the control, alt, and command buttons.
I was very suprised to press control alt delete on the apple keyboard and it worked on my pc.... |
Re: Apple Keyboard on Windows 7
Unfortunately some of the key commands on PC are different. Had to struggle with that myself, until I switched back to Mac again.
Would be nice to know what happens with an Apple keyboard. Guess it won't do much good, but please keep us posted on that one.
iMac Pro - MacOS 10.14.6 --- - Pro Tools U HDN 2019.6 - Avid HD Omni + HD I/O 8x8x8 - C|24 | S3 | Dock |
yeah i figured that would be the case.
Could you give me an example of what key commands are different? |
It's been a while, so I can't really remember, but two particularly annoying ones were:
- The "move cursor down" command. On Mac it's ";", on PC it was "[". - Switching to volume automation view. On Mac it's "-" on PC it's "/".
I use a mac keyboard on my PC Pro tools, I was trained on a PT mac so to help me avoid learning all PC key commands again, I use keytweak to change my pc keyboard layout into mac keyboard layout, then hook a mac keyboard to my PC and viola!
here's the link to download keytweak: http://webpages.charter.net/krumsick/ the only 2 commands that I am aware of that will be different even with keytweak mac keyboard layout is: 1) backwards TAB: instead of ALT+Tab, use COMMAND+TAB 2) going to end of session: instead of ALT+RETURN use COMMAND+Return. |
Best |
Hey - can you report if that little Keyboard tweak has worked? I'm considering to do the same and don't want to learn PC key commands. So it would be really nice if you could tell if there where any problems...thanks a lot |
i'm a little confused which key on the mac layout you mapped to which key on the pc layout or vice versa. Isn't it rather: leave the control key where it is (because both mac and win are on the very left). Map the alt key on the mac keyboard with wins "alt" key and the command key on the mac keyboard with wins "windows"key???? - because the only difference if you regard it from the 'windows-point-of-view' is that on a mac keyboard the windwos key and alt key are inverted??? |
Basically CTRL = CMD .
CMD = CTRL the only thing that i have found that is different is option tab to move backward its ctrl tab on a pc. |
Keyboard Shortcuts-Apple Thin Keyboard | Brian in Charlotte | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-15-2008 03:17 PM |
keyboard shortcuts without an Apple keyboard? | doublestakked | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-22-2006 05:04 AM |
apple "pro" keyboard | Bryan Cook | Pro Tools TDM Systems (Mac) | 0 | 08-17-2004 12:48 PM |
OT: Apple Keyboard Shortcuts | NannerPuddin' | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 10-24-2003 11:32 AM |
OT -hi res pic of apple pro keyboard? | beardeddubster | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-18-2002 04:06 PM |
