Avid Pro Audio Community |
access violation occurred, unable to read location: 0x00000000 at address:0x5ad45a48 in module: kontakt 4 dpm
What is this? i get this message everytime i open kontakt 4. SiSoftware Sandra Computer Workgroup : WORKGROUP Host Name : Oscar-Dator User : Oscar Processor Model : AMD Phenom(tm) II X4 945 Processor Speed : 3GHz Cores per Processor : 4 Unit(s) Threads per Core : 1 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 64kB, Synchronous, Write-Back, 2-way, Exclusive, 64 byte line size L2 On-board Cache : 4x 512kB, ECC, Synchronous, Write-Back, 16-way, Exclusive, 64 byte line size L3 On-board Cache : 6MB, ECC, Synchronous, Write-Back, 48-way, 64 byte line size, 4 threads sharing Computer Mainboard : Gigabyte M57SLI-S4 BIOS : Award (Phoenix) FHL 11/06/2009 Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 8GB DIMM DDR2 Chipset Model : AMD F10h Athlon 64/Opteron/Sempron HT Hub Front Side Bus Speed : 2x 1GHz (2GHz) Total Memory : 8GB DIMM DDR2 Channels : 2 Memory Bus Speed : 2x 402MHz (804MHz) Memory Module(s) Memory Module : A-Data 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-23-6-3) Memory Module : A-Data 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-23-6-3) Memory Module : A-Data 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-23-6-3) Memory Module : A-Data 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-23-6-3) Video System Video Adapter : NVIDIA GeForce 8600 GT (32 SM4.0 1.1GHz, 256MB DDR3 2x704MHz, PCIe 1.00 x16) Graphics Processor OpenCL Processor : NVIDIA GeForce 8600 GT (32SP 4C 1.19GHz, 231.6MB 2x704MHz) CUDA Processor : NVIDIA GeForce 8600 GT (32SP 4C 1.19GHz, 231.6MB 2x704MHz) Compute Shader Processor : NVIDIA GeForce 8600 GT (32SP 1.1GHz, 231.6MB 2x704MHz) Storage Devices Seagate ST3802110A (80GB, ATA100, 3.5", 2MB Cache) : 75GB (D:) SAMSUNG HD103SJ (1TB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 932GB (C:) Hitachi HDS721616PLA380 (160GB, SATA300, 3.5", 7200rpm, NCQ, 7MB Cache) : 149GB (F:) SAMSUNG HD753LJ (750.2GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 699GB (G:) TSSTcorp CDDVDW SH-S223F (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (H:) AJSHSTO S1QF4D2 (SCSI, BD-R, HD-DVD-R, DVD+-R-DL, CD-R) : N/A (K:) Logical Storage Devices Hard Disk (D:) : 75GB (NTFS) @ Seagate ST3802110A (80GB, ATA100, 3.5", 2MB Cache) Reserverad av systemet : 100MB (NTFS) Hard Disk (F:) : 149GB (NTFS) @ Hitachi HDS721616PLA380 (160GB, SATA300, 3.5", 7200rpm, NCQ, 7MB Cache) Hard Disk (G:) : 699GB (NTFS) @ SAMSUNG HD753LJ (750.2GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) Hard Disk (C:) : 931GB (NTFS) @ SAMSUNG HD103SJ (1TB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) Optical Drive (H:) : N/A @ TSSTcorp CDDVDW SH-S223F (SATA150, DVD+-RW, CD-RW, 2MB Cache) Optical Drive (K:) : N/A @ AJSHSTO S1QF4D2 (SCSI, BD-R, HD-DVD-R, DVD+-R-DL, CD-R) Peripherals LPC Hub Controller 1 : Giga-Byte MCP55 LPC Bridge LPC Legacy Controller 1 : ITE IT8716F Audio Device : Giga-Byte MCP55 High Definition Audio Audio Codec : Realtek Semiconductor 888 High Definition Audio Serial Port(s) : 1 Parallel Port(s) : 1 Disk Controller : Giga-Byte MCP55 IDE Disk Controller : Giga-Byte MCP55 SATA Controller Disk Controller : Giga-Byte MCP55 SATA Controller Disk Controller : Giga-Byte MCP55 SATA Controller USB Controller 1 : Giga-Byte MCP55 USB Controller USB Controller 2 : Giga-Byte MCP55 USB Controller FireWire/1394 Controller 1 : Giga-Byte TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller SMBus/i2c Controller 1 : nVidia MCP5+ SMBus 1 SMBus/i2c Controller 2 : nVidia MCP5+ SMBus 2 Printers and Faxes Printer : Send To Microsoft OneNote 2010 Driver (1200x1200, Colour) Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : NVIDIA nForce 10/100/1000 Mbps Ethernet (Ethernet, 100Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7600 Platform Compliance : x64 Windows Experience Index Current System : 5.9 Performance Tips Warning 100 : Large memory sizes should be made of Registered/Buffered memory. Tip 2546 : Large memory modules should be ECC/Parity. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. |
Which exact numeric version of Kontakt 4? Have you checked the Native Instruments website (or the NI Service Center) for updates?
Which version of Pro Tools? (I'm guessing 8.0.4 or 9, but...)
My Website: Pro Tools "Newbie" Help New studio rig: Gigabyte GA-EX58-UD3R, Intel i7 920, 6GB Patriot DDR3. ASUS EN7600GT, LG GGW-H20L BD-RE, Sony CRX195E1 CD-RW, 2x ICY DOCK MB671SK-B (trayless hotswap), 2x WD Caviar black 640GB (os swap), 1x WD caviar 320GB (sessions), 1x Maxtor 120GB (sessions), 1x Seagate 1TB (samples/loops) |
For me this issue had nothing to do with Kontakt. But perhaps this helps.
Possible solution (assumption): Win 7 Professional RME Fireface 800 PT 9.0.0 I had the same problem after working a while with projects in 192 kHz. When I tried to open an older session in 48 kHz I got these errors on opening every session and backup. Scary! ![]() I noticed that PT switches automaticly to my MBOX 2 driver and my Fireface switches automaticly to 192 kHz while opening a session. My solution: - set the samplerate again to the sessions setting manualy - set the buffer size to the value with which you saved the session or in my case 512 samples - switch drivers in PT to Fireface (or your device) I hope that helps! ![]() @ Avid: This was the worst error i had so far. Please work on these things. We all paid a lot of money. Such a mayor error one day before deadline is no fun at all!!!! ![]() . .
http://protools.ideascale.com/a/dtd/...ng/107607-3779 |
I love usin Pro Tools, but hell Im sick of the fact I cannot guarentee that it will start when I turn on my computer, Im sick of the fact that it doesn't start and has some hissy fit when I have changed nothing. I just want to do some work and not worry about my software letting me down all the time. |
I'm having these SAME problems. On Windows 7 with similar processor power to yours as well...this access violation is really driving me insane. I can't do ANYTHING! I can't even open a new file! I need some freaking HELP AHHH!!
I would startup your pc and press delete or whatever brings up setup and disable the onboard sound drivers. Then make sure that you have all the latest drivers foe your interface and midi.
F |
The other I noticed which may not be a problem but I had Nvidia Graphics card and PT10 kept crashing. I changed to radeon on Digi advice and ALL was cured instantly. Check that your graphics card is certified by avid if possible as can really be big problem if not.
F |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Access violation occurred, unable to write location 0x5A9075A8 | Niilo Nuori | Pro Tools Software (Win) | 2 | 12-07-2012 07:08 PM |
| access violation occurred, unable to read location: 0x00000002 at address: 0x00B9A020 | nickmadsen | Mbox, Mbox 2, Digi 001, Digi 002, 003 (Win) | 0 | 12-04-2011 11:34 AM |
| access violation occurred, unable to read location: 0x00000000 at address:0x5ad45a48 | moonwalker2 | Mbox, Mbox 2, Digi 001, Digi 002, 003 (Mac) | 2 | 12-28-2010 10:20 AM |
| Access violation occurred, unable to read location: 0x00000004 at address: 0x075FE866 | JagPaw | Mbox, Mbox 2, Digi 001, Digi 002, 003 (Win) | 4 | 07-24-2010 11:35 AM |
| Access violation occurred, unable to read location: 0x00000170 at address: 0x0478b420 | sayed mohammed | Mbox, Mbox 2, Digi 001, Digi 002, 003 (Win) | 4 | 04-15-2009 03:09 PM |
