Old 12-28-2010, 09:59 AM
moonwalker2 moonwalker2 is offline
Default access violation occurred, unable to read location: 0x00000000 at address:0x5ad45a48
access violation occurred, unable to read location: 0x00000000 at address:0x5ad45a48 in module: kontakt 4 dpm
What is this? i get this message everytime i open kontakt 4.
SiSoftware Sandra
Computer
Workgroup : WORKGROUP
Host Name : Oscar-Dator
User : Oscar
Processor
Model : AMD Phenom(tm) II X4 945 Processor
Speed : 3GHz
Cores per Processor : 4 Unit(s)
Threads per Core : 1 Unit(s)
Type : Quad-Core
Integrated Data Cache : 4x 64kB, Synchronous, Write-Back, 2-way, Exclusive, 64 byte line size
L2 On-board Cache : 4x 512kB, ECC, Synchronous, Write-Back, 16-way, Exclusive, 64 byte line size
L3 On-board Cache : 6MB, ECC, Synchronous, Write-Back, 48-way, 64 byte line size, 4 threads sharing
Computer
Mainboard : Gigabyte M57SLI-S4
BIOS : Award (Phoenix) FHL 11/06/2009
Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
Total Memory : 8GB DIMM DDR2
Chipset
Model : AMD F10h Athlon 64/Opteron/Sempron HT Hub
Front Side Bus Speed : 2x 1GHz (2GHz)
Channels : 2
Memory Bus Speed : 2x 402MHz (804MHz)
Memory Module(s)
Memory Module : A-Data 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-23-6-3)
Video System
Video Adapter : NVIDIA GeForce 8600 GT (32 SM4.0 1.1GHz, 256MB DDR3 2x704MHz, PCIe 1.00 x16)
Graphics Processor
OpenCL Processor : NVIDIA GeForce 8600 GT (32SP 4C 1.19GHz, 231.6MB 2x704MHz)
CUDA Processor : NVIDIA GeForce 8600 GT (32SP 4C 1.19GHz, 231.6MB 2x704MHz)
Compute Shader Processor : NVIDIA GeForce 8600 GT (32SP 1.1GHz, 231.6MB 2x704MHz)
Storage Devices
Seagate ST3802110A (80GB, ATA100, 3.5", 2MB Cache) : 75GB (D:)
SAMSUNG HD103SJ (1TB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 932GB (C:)
Hitachi HDS721616PLA380 (160GB, SATA300, 3.5", 7200rpm, NCQ, 7MB Cache) : 149GB (F:)
SAMSUNG HD753LJ (750.2GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 699GB (G:)
TSSTcorp CDDVDW SH-S223F (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (H:)
AJSHSTO S1QF4D2 (SCSI, BD-R, HD-DVD-R, DVD+-R-DL, CD-R) : N/A (K:)
Logical Storage Devices
Hard Disk (D:) : 75GB (NTFS) @ Seagate ST3802110A (80GB, ATA100, 3.5", 2MB Cache)
Reserverad av systemet : 100MB (NTFS)
Hard Disk (F:) : 149GB (NTFS) @ Hitachi HDS721616PLA380 (160GB, SATA300, 3.5", 7200rpm, NCQ, 7MB Cache)
Hard Disk (G:) : 699GB (NTFS) @ SAMSUNG HD753LJ (750.2GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache)
Hard Disk (C:) : 931GB (NTFS) @ SAMSUNG HD103SJ (1TB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache)
Optical Drive (H:) : N/A @ TSSTcorp CDDVDW SH-S223F (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Optical Drive (K:) : N/A @ AJSHSTO S1QF4D2 (SCSI, BD-R, HD-DVD-R, DVD+-R-DL, CD-R)
Peripherals
LPC Hub Controller 1 : Giga-Byte MCP55 LPC Bridge
LPC Legacy Controller 1 : ITE IT8716F
Audio Device : Giga-Byte MCP55 High Definition Audio
Audio Codec : Realtek Semiconductor 888 High Definition Audio
Serial Port(s) : 1
Parallel Port(s) : 1
Disk Controller : Giga-Byte MCP55 IDE
Disk Controller : Giga-Byte MCP55 SATA Controller
USB Controller 1 : Giga-Byte MCP55 USB Controller
USB Controller 2 : Giga-Byte MCP55 USB Controller
FireWire/1394 Controller 1 : Giga-Byte TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller
SMBus/i2c Controller 1 : nVidia MCP5+ SMBus 1
SMBus/i2c Controller 2 : nVidia MCP5+ SMBus 2
Printers and Faxes
Printer : Send To Microsoft OneNote 2010 Driver (1200x1200, Colour)
Printer : Microsoft XPS Document Writer (600x600, Colour)
Network Services
Network Adapter : NVIDIA nForce 10/100/1000 Mbps Ethernet (Ethernet, 100Mbps)
Power Management
Mains (AC) Line Status : On-Line
Operating System
Windows System : Microsoft Windows 7 Ultimate 6.01.7600
Platform Compliance : x64
Windows Experience Index
Current System : 5.9
Performance Tips
Warning 100 : Large memory sizes should be made of Registered/Buffered memory.
Tip 2546 : Large memory modules should be ECC/Parity.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
Old 12-28-2010, 10:50 AM
Park Seward's Avatar
Park Seward Park Seward is offline
Default Re: access violation occurred, unable to read location: 0x00000000 at address:0x5ad45
This is the MAC forum. You will have better luck on the WINDOWS forum.
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 12-28-2010, 11:20 AM
oh thanks for the heads up. no wonder i got no replies!
Access violation occurred, unable to read location: 0x000000003E3FFFBA pm mastering studio Pro Tools 11 17 05-13-2015 02:37 PM
access violation occurred, unable to read location: 0x00000002 at address: 0x00B9A020 nickmadsen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-04-2011 12:34 PM
access violation occurred, unable to read location: 0x00000000 at address:0x5ad45a48 moonwalker2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 11-22-2011 11:00 AM
Access violation occurred, unable to read location: 0x00000004 at address: 0x075FE866 JagPaw 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-24-2010 12:35 PM
Access violation occurred, unable to read location: 0x00000170 at address: 0x0478b420 sayed mohammed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-15-2009 04:09 PM
