Old 12-25-2010, 11:43 PM
chirotay chirotay is offline
Smile DAE error 9060 was encountered
Hi I just loaded Pro tools avid recording studio M audio on a brand new windows 7 laptop I can hear everything good through the head phones and then I recorded a little test and when I played it back to listen I got a
(DAE error 9060 was encountered) message. Can anyone assist me in fixing that?
Actually I'm getting a bunch of these errors like 9031 and 9507
Is there anyplace wher I can go to read up on these and. HELP...
Thanks
Tom
Old 12-29-2010, 09:07 AM
sonicgraffiti sonicgraffiti is offline
Default Re: DAE error 9060 was encountered
Uninstall PT completely. Update all audio hardware drivers to the most current workable version for your OS (to include bit version), and re-install a clean version of PT after all of that is complete. I had to do this, and it cleaned up the DAE error problems. Also, be carefull to power up your interface BEFORE booting up your PC. Hope this helps.
As a side note, I got a lot of these when I was using 32-bit Win 7 on a PC that I recently had upgraded all hardware to handle 64-bit (motherboard, processor, RAM, and video card). It didn't like the lower-grade OS on the higher grade hardware.
Old 01-02-2011, 09:07 AM
panpan75 panpan75 is offline
I had the same issue (DAE error 9060, 9031) I did a "Save copy in" and copied all my files (plugins,audio files, ect..) and it seemed to fix the issue.
The session looks exactly the same and I'm not getting errors.
Old 10-01-2013, 11:10 AM
Scavneck Scavneck is offline
I had this error appear to me when I tried opening an older project. I changed my buffer and latency settings and it started working again.
Old 10-02-2013, 05:06 PM
DC-Choppah DC-Choppah is offline
You need to find out what sample rate (41.4 khz, 48 khz, etc.) and buffer size and disk settings your machine can keep up with.
DC-Choppah's Project Studio:
ASUS P5Q Pro Turbo /Intel Pro 2 Quad Core-rackmount PC
Windows 7 professional 64 bit
Pro-Tools 11.3.1
AIR Instrument Expansion Pack v2
WAVES Platinum plugin bundle
M-AUDIO FastTrack ULTRA 8R Interface
Roland RD-300 / Novation XiO Keyboards
Mackie 12 channel Analog Mixer
Adam A8X monitors
Estonia Parlor Grand Piano
Yamaha Studio Drum kit
https://soundcloud.com/dc-choppah
PT9 DAE error 9060 was encountered Jolly77 Pro Tools Software (Mac) 3 04-03-2011 06:38 AM
DAE error - 9060 was encountered. Help???? time808 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-24-2004 11:47 AM
DEA error 9060 was encountered. BOMBA 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-26-2002 10:19 PM
DAE Error-9060 Was Encountered recordingguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-28-2002 09:46 PM
DAE error - 9060 encountered txchain Digidesign Hardware & Software 1 04-28-2002 07:07 PM
