Old 12-23-2010, 01:44 PM
Scott Fahy Scott Fahy is offline
Default TDIF to MADI Question
We have 8 Aphex 1788's preamps (64) with the digital output card installed in our I/O room. Currently the ADAT out feeds the digital inputs on our FOH stage rack, the AES/EBU of the Aphex routes to the broadcast studio (Yamaha DM200's). I'd like to see if we can do a TDIF to MADI conversion in the I/O room and use that to get into a Mix Rack set up at monitor world with the MADI card.
Scott
Old 12-23-2010, 02:58 PM
Craig F Craig F is offline
Default Re: TDIF to MADI Question
http://euphonix.com/pro/broadcast/digital-format.php
a used 727 might be cheaper (they can look like 888s to Pro Tools)
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 12-23-2010, 07:26 PM
Thanks Craig... that one only does 56 and we have 64 channels on the Aphex units so I'd lke to find something that can handle 64 channels (or 2 32 channel units would work too) if possible
Old 12-23-2010, 07:54 PM
Kenmillerjr's Avatar
Kenmillerjr Kenmillerjr is offline
Hey man. I had looked at a similar situation a few months back...I needed 64 channels o f MADI not 56. It was a very expensive option. I had to figure out another plan. Idk why som manufactures are locked to 56, when the standard for MADI is 64.
Ken Miller, Jr.
Audio Engineer
Southside Baptist Church | Warner Robins, GA
| VENUE Profile 96X64 with MADI Option | ProTools 7.4.2 HD3 Accel PCI | ProTools 10 Native | MacBook Pro 17" OS 10.7.1 2.3GHz Intel Core i7 8GB Ram | Mbox 2 Pro | Mbox 3 Pro | Motu 896mk3 Hybrid |
Old 12-23-2010, 10:35 PM
MADI use to only be 56 channels, not a problem with 3348 or D827s
64 is a bump that only happened in the last 5 years or so
maybe a few of this Sydec box and a MADI hub
http://www.sydec.be/Products/Details...Box+64-MADI-T/
or convince them to roll what you need 8 TDIF by 1 MADI
Thank you,
Craig
Old 01-01-2011, 08:38 AM
Chris Johnson Chris Johnson is offline
the other reason for the MADI format difference is some manufacturers using the last '8 channels' for control or other data streams instead.
you want one of these: http://www.rme-audio.de/en_products_adi_648.php
If will convert the ADAT to MADI and still duplicate the ADAT inputs to the ADAT outputs. So basically this will sit inline between the pre's and the stage rack and give you a MADI split out to our Mix Rack.
Old 01-01-2011, 09:30 AM
Chris,
That is just we are looking for. Thanks very much.
Scott
HD MADI Supports Frame Pattern MADI ??? misterGOLD Pro Tools HDX & HD Native Systems (Mac) 2 02-10-2014 11:43 PM
TDIF question? ctyelvis Pro Tools TDM Systems (Mac) 8 11-30-2009 07:15 AM
TDIF SYNC I/O clock question jimlongo Post - Surround - Video 0 01-25-2005 02:27 PM
192 I/O to Dsm71 Tdif cable question SurroundNewbie Post - Surround - Video 3 02-18-2004 09:43 AM
888 - AES to Tdif, or MADI convertors? David Lamb Post - Surround - Video 6 03-13-2003 09:48 AM
