Old 11-13-2010, 03:42 AM
mgoorevich's Avatar
mgoorevich mgoorevich is offline
Default Slip to Grid mode no visual grid unless pressing "grid"
I upgraded from PT HD 7.4 so may be I am missing something (probably it was invented in PT8) ....
However in PT HD 9 when switching between slip mode and grid mode I expect to see the grid separation (frames) in grid mode and clean timeline when in slip mode.
The thing is when clicking on Time Code ruler grids appear or hide like it was before but I want it follow my mode. Without pressing each time on the TC ruler or "Grid" (selecting it green) in the Grid/Nudge value window.
I want Grids when I press F4 and I want NO grid when I press F2.
What am I missing after 10 years using Pro Tools?
For me as PT HD 7.4 user and PT HD8 skipper it looks like a bug...
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
PT HD⎪N v2020.12 Ultimate ● macOS High Sierra 10.13.6
MacPro 2 x 2.4 GHz Quad-Core Intel Xeon ● 24 GB RAM
MTRX Studio + MOM ● Sync HD ● AJA LHi referenced by AJA GEN10 ● D-Command ES24
Old 11-13-2010, 04:03 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Slip to Grid mode no visual grid unless pressing "grid"
Just had a play at home on my le and laptop and i see what you mean!! i have gone from grid mode to slip and the grid lines are still showing?
I guess they decided to leave grid visible as a reference!! but slip is free floating still.
Chris
Producer, Engineer,
www.ukmastering.com
Old 11-13-2010, 04:20 AM
mgoorevich's Avatar
Hi Chris,
Yes, it's true you can freely slip while seeing the grid lines.
But I am waiting for the dialog (or even all post folks) editors to jump up with this issue.
Also, just like you, I am playing with my PT HD9 on my Mac Mini at home.
I see that the ADC is not working. EG inserting some heavy reverb on some track will not reflect any compensations on others how it should.
Maybe its looking and counting for the TDM chips?
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
Old 11-13-2010, 06:36 AM
formfunction formfunction is offline
Hi Chris,
specifically, which plugs?
Have you tried it with standard Avid plugs?
When you mention "looking for TDM chips" are you saying that you have TDM plugs open? probably not, but .....fff
Old 11-13-2010, 06:53 AM
crizdee's Avatar
Now that would be something!!!! I'm just waiting for someone to say they're running as TDM plug natively
Chris
Producer, Engineer,
www.ukmastering.com
Old 11-13-2010, 07:11 AM
mgoorevich's Avatar
Chris
I love it too!!!!!!!!!!!
No no no just installed a freash PT HD9. No plugins (only digirack and air ones).
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
[IMG] code is Off
Viewing grid in slip mode remusjacobs macOS 2 10-15-2012 02:41 PM
Grid Lines in Slip Mode 9.0.5? anackman macOS 3 09-15-2011 03:24 PM
Removing Vertical Grid Lines while in Slip Mode teacherman Tips & Tricks 3 06-08-2010 12:32 PM
Grid Lines - Slip Mode vs. Grid Mode Mt.Everest Pro Tools TDM Systems (Mac) 24 02-20-2006 08:38 AM
Shuffle ,Slip ,Spot and Grid mode chucky dinamico 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-15-2003 06:44 PM
