Avid Pro Audio Community |
hi, i'm trying to create a stutter effect in PTHD2 but all i get are clicks when automate the mute, either using 1/16 1/32 1/64 grid resolution, this is what i learn from different tutorials on the web, two ways: making automation with the pencil tool, or muting the regions. automating volume with square pattern makes only clicks. I'm on HD2, version 8.1cs2 mac pro dual core 2.66
no clicks are allowed on a 7000k DAW!!! |
There are two problems with trying to do this with mute automation. First, you get clicks, and second, automation is not sample accurate.
It would be better to do this by editing the audio region instead. In grid mode, you can delete the parts you want muted, and then apply short fades to the kept regions to eliminate any clicks.
James Cadwallader "Men occasionally stumble over the truth, but most of them pick themselves up and hurry off as if nothing had happened." -Winston Churchill |
thanks jimmy, i didn't try this alternative way just because i wanted to try the fastest way (automating mute) so automation is not sample accurate with volume probably because is to fast 1/16 or 1/32, but in the tutorial on you tube they did it!!! (maybe was an LE sistem 7.4) going to try muting by hand and fades, thanks
If you turn the auto fade in/out setting in preferences to 10ms, you might get rid of the pops and then you wouldn't have to manually creates fades.
But I've done this as the other poster said, by making edits, and either deleting or muting pieces. It's time consuming, but it works. Mooger Fooger Ring Modulator can do a 'similar' sound, not quite the same, but might work for what you want it to do as well. |
I am pretty sure the Transfuser plugin does the "stutter" effect
Joe |
yeah, i remember the bold guy on digi tv saying: i'm having so much fun using transfuser. will try that one also thanks to a---l----l----!
Here's My Little Workflow For The Stutter Effect
There are MANY other way's to achieve this, but I read this thread, Knowing I wanted to do this edit, so i pulled it up and did a Screen cap.
David - Trident TSM 52 Input Console - HDX / OMNI / HD i/o's - MacPro 8 Core 2.4 Westmere 28Gb RAM - PT HD 10.3.3 + H.E.A.T. OS X 10.8.2 - SSL Nucleus Controller - Dynaudio Acoustics BM6A's / Genelec 8040a / NS10's w/ Sub - 1176's, LA2A's, ADL CL1500, Neve 1073's, 16 x Wunder Audio Pre's, Ward Beck's, API's, Misc Vintage outboard. - 2x - HD3 Accel PCIe - 192 i/o's - 96 i/o's |
Hey Phil - thats a clever Workflow. thats the beauty of Pro-Tools - 10 different ways to accomplish the same thing.
You can trigger a gate with structure free. Change in duration and tempo are easier than moving automation points.
JC |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| I need help creating a vocal effect | HMT | Mbox, Mbox 2, Digi 001, Digi 002, 003 (Win) | 7 | 12-06-2010 10:13 AM |
| Jamie Foxx feat T-Pain "Blame it" Stutter effect. | 29th of July | General Discussion | 9 | 09-11-2009 01:01 PM |
| Stutter effect | t0rn | Mbox, Mbox 2, Digi 001, Digi 002, 003 (Win) | 3 | 06-09-2009 07:36 PM |
| Stutter effect | blackfader | Mbox, Mbox 2, Digi 001, Digi 002, 003 (Mac) | 4 | 09-16-2008 05:13 AM |
| timed stutter effect...LIke tremilo but not | monkey | Tips & Tricks | 10 | 06-30-2002 02:45 PM |
