Record from youtube into Pro Tools
I want to record a piece of sound from youtube.
What is the easiest way to do it? |
Re: Record from youtube into Pro Tools
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
If that doesn't work, I just use a second PC for connecting the the internet(where my PT machine seldom goes) and run a cable from the line out to my 003.
easiest way is to use Safari to download the video from Youtube. (once the video is playing press command option A to get the activity window. Find the one entry that is in Megs not KB and double click it. the video will download. rename the file xxxx.flv and you have the vid. Then you can use iextractmp3 to get the mp3 of the audio. then you can import that into pro tools. You can google iextractmp3, its free. Hope this helped. Chris |
Very useful for recording any digital audio that is being passed throughout the system. I use it to record the audio from concert DVDs so I can take it with me.. (among other things)
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
I made an aggregate device consisting of my Mbox 2 Pro and Soundflower (2 ch), and chose the device in the Apple System Preferences (Input and Output), the Audio-MIDI Setup, and the Playback Engine in PT. The Soundflower inputs show up as available inputs in PT, but I don't know how to get the output of Youtube to register on an Audio Track in PT. I also tried getting audio from Kontakt (in stand-alone) into Pro Tools, but didn't succeed. Any information would be appreciated. |
I figured it out. For anyone else interested, here's what to do:
1. Download and install Soundflower. 2. In Audio/MIDI Setup, make an Aggregate Device consisting of your audio interface (Mbox 2 Pro, for example) and Soundflower (2 ch). 3. In Mac > System Preferences > Sound, set "Output" to Soundflower (2 ch). This forces the System audio to Soundflower. 3. In PT, set the Playback Engine to the Aggregate Device you made. 4. In PT > Setup > I/O > Input, rename the inputs if necessary to make them easier to find when selecting inputs on an Audio or Aux Track. Clicking "Default" may help. 5. In PT, create an Audio or Aux Track, and select the Soundflower input. 6. Play the Youtube video, record-enable the track in PT, and you should hear the audio coming from Youtube. Do something good. |
would this work in pt le 8? ----> http://www.ntonyx.com/vac.htm
Win 7 64 bit AMD Phenom(tm) II X4 965 Processor Mainboard : Asus M4A78T-E BIOS : AMI 2402 01/05/2010 Chipset AMD RS780 Host Bridge Memory 6 gigs ddr3 1600mhz Memory OCZ OCZ3G1600LV2G 2GB DIMM DDR3 PC3-8500U DDR3-1066 (7-7-7-16 4-26-8-4) X 3 for 6 gigs Video Adapter : ATI Radeon HD 4870 X2 Western Digital Black 1TB, SATA300,7200 rpm 64MB Cache 932GB For PT WDC 500.1GB, SATA300,7200rpm, NCQ, 16MB Cache For Recording http://www.vampirefreaks.com/dawnofblack |
Interesting, for sure, but I will stick with my method as it only takes a cable
Youtube video about development of Pro Tools hardware since early days | peter5992 | General Discussion | 4 | 05-16-2013 08:43 PM |
QuickTime MOV Exported from Pro Tools Will Not Process at YouTube? | wdjudd | macOS | 15 | 02-04-2013 11:24 AM |
check out this guy writing a song on YouTube (Pro Tools) | benny99 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-08-2008 02:58 PM |
Amazing Youtube video of FAST Pro Tools songwriting | benny99 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-08-2008 12:57 PM |
Pro Tools bug videos on YouTube | poly915 | Pro Tools TDM Systems (Mac) | 64 | 10-03-2007 09:21 AM |
