Community Terms of Use
Google Search | Search Knowledge Base | Search Avid.com
Find Support | Pro Tools Support Videos | Support FAQ
Software Updates, Drivers, Manuals, Compatibility, Troubleshooting, etc. (Links)
Please post your message once only to the correct forum
Help us Help You - READ THIS Before Posting!
Pro Tools 11
Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 11-06-2010, 01:59 PM
justus1900 justus1900 is online now
Default Windows 7 and Pro Tools 9
I just added a brand new 500GB Hard Drive to my computer and loaded a fresh install of Windows 7 Professional that I bought today. Since I decided to not over write my old very stable OS Vista Business Hard Drive. (I put that HD away in case Pro Tools 9 crashes, isnt stable or just sucks..Ha Ha Ha) this way I can allways just put that HD back in my computer and be right were I was before. My question is do I need to load my Pro Tools 8 M-Powered to my fresh Windows 7 install to be able to crossload update Pro Tools 9?
Producer/Engineer/Musician
RIAA Platinum Sales Award: Lisa Stansfield "Affection"
Model: Dell Precision T1500 Minitower
OS: Windows 7 64 Bit
CPU: Intel® Core™ i7-860 (2.8GHz,8MB)
Memory: 16GB (4 X 4GB)
Internal Hard Drives:
500GB=OS/Pro Tools/Plug-Ins
750GB= Recording
500GB=Sounds/Back Up
Ext. Hard Drives:
500GB=Glyph GT 050Q FW
250GB=ULTRA Caddy USB
M-Audio: Fast Track C600
Pro Tools 10.3.3
Old 11-06-2010, 02:25 PM
jayzed jayzed is offline
Default Re: Windows 7 and Pro Tools 9
That's a very good question. I decided to try PT9 on my clean Win 7 laptop as my main machine is still XP. Install went fine but PT force closes at the end of it's plugin check (that's a rather annoying place in the startup for it to decide not to work) saying it can't find an interface, despite having a working ASIO interface (tested using other apps) plugged in via USB.
I installed my M-P interface in the vain hope that it would work with a known working m-audio interface and hopefully let me change over to my ASIO interface in setup but no joy.
Unless this is a bug thing, my next idea is that maybe I needed to have PT8MP on the machine and downloaded the upgrade installer?
I can't find a list of known working ASIO interfaces although I believe one must exist somewhere.
At the moment, I have an expensive file taking up space on my HD which is rather frustrating.
Old 11-06-2010, 02:39 PM
Originally Posted by justus1900 View Post
do I need to load my Pro Tools 8 M-Powered to my fresh Windoes 7 install to be able to crossload update Pro Tools 9?
No. Pro Tools 9 is a full standalone installer.
Aaron Mulqueen
Old 11-06-2010, 11:35 PM
M-ManLA's Avatar
M-ManLA M-ManLA is offline
Usually PT takes a while when you are first booting up for the first time with it. Load it up without installing any extra plugins. That will make it go faster. But Open it and leave it for abot 5mins and it should be ok.
Old 11-07-2010, 12:08 AM
M-ManLA's Avatar
Try this, Just read it from http://www.airusersblog.com/home-pag...and-fix-p.html
Old 11-11-2010, 12:36 PM
I worked it out, I reckon.
It seems PT will not work with ASIO drivers that do not use 32, 64, 128, 256 etc buffer values.
I'm happy I know what it is.
Do you know, every other single application, every single one, that I have run has lived with non-byte aligned buffer values.
If this is truly what is causing the problem, I am a little disgusted. I suppose the transfer of the Digi DAE code to ASIO brought the limitation across (although it's not a limitation when using Digi interfaces 'cause that's all they do) but everyone else (including the bedroom coder) manages it.
I love the PT editing paradigm but I've always felt that their coding was a whisker suspect.
Please correct me if anyone can get an EMU 1820m working, or a Kore 1, or if I'm wrong about this.
It seems I can get PT to work fine when using the MOTU but I didn't want to use that on the machine I planned to run PT9 on. Never mind.
Old 10-20-2011, 02:09 PM
mrflat mrflat is offline
Hello guys!
I need your help
has a long history ....
I work with a PC O / S win7, with ProTools, 2 RME Fireface 800 and a DM2000 as a remote control or a simple mixer ... great stuff
Firefaces are connected via ADAT to the DM2000 MY8-AT through 4, and are connected to the PC via FireWire 800.
in the I / O setup protools9 I can see all the default inputs of both RME, 28 inputs and outputs
if I try to do a mix of a song with 32 audio tracks mono, I can only handle the first 16 out of the Fireface first, there is no output signal from the second Fireface.
In the window protools9 mix, however, I see the presence of signal on all 32 tracks.
if I try to record an instrument, such as a keyboard, connected to the inputs of the second Fireface front, (1,7,8,9,10), the signal passes through the Fireface but does not exit from pt9
P: S: none of this happens with other software
can someone give me a hand?
Thanks to all
mrflat
Old 10-20-2011, 06:43 PM
albee1952 albee1952 is online now
Originally Posted by mrflat View Post
Hello guys!
I need your help
Thanks to all
mrflat
I would start a new thread with this
Gigabyte GA-EX58A-UD3R, Intel i7 950, 12 gig Corsair DDR3, PNY GeForce 210, Focusrite ISA428, Octopre Mk II Dynamic, Lucid GenX192, DIGI003 running PT10HD, Vintech and Five Fish preamps..............................
http://www.myspace.com/cswstudio
www.capricornsoundworks.com
The cool thing about digital is; there's 4 ways to do everything. The bad thing about digital is; there's 4 ways to...........
Upgrade From Pro Tools LE (Windows XP) to 10 (Windows 7) miek07 Pro Tools Software (Win) 3 07-26-2012 06:49 PM
Updating Pro Tools and Mbox from Windows XP to Windows 7 ryanjantz Mbox, Mbox 2, Digi 001, Digi 002, 003 (Win) 1 05-29-2011 03:22 PM
Complex Pro Tools Problem: Windows 7 & Pro Tools 7 & 8 kremo5le Mbox, Mbox 2, Digi 001, Digi 002, 003 (Win) 4 10-11-2010 08:42 PM
Opening a pro-tools HD session on a windows Pro-Tools LE M-powered system rhodamorgan Mbox, Mbox 2, Digi 001, Digi 002, 003 (Win) 1 09-21-2010 04:31 PM
Pro Tools LE vs. Pro Tools M-Audio - Any difference? Windows 7 gbross Mbox, Mbox 2, Digi 001, Digi 002, 003 (Win) 1 11-21-2009 07:24 PM
