Old 01-14-2003, 01:54 PM
monkey monkey is offline
Default convert kick and snare track to midi...
Any one know a good way to take an audio track of snare or kick drum and convert it to midi to trigger a midi device? thanks
Old 01-14-2003, 03:56 PM
Steve MacMillan Steve MacMillan is offline
Default Re: convert kick and snare track to midi...
There are several outboard boxes like a Forat f16 or an Alesis DM-Pro, that will take audio triggers and turn them into midi notes.
What you may want to do is to use Beat Detective to slice up a copy of your snare track. Then with a midi track sitting just above that snare track. You can select across both tracks and paste a midi note by tabbing from cut to cut. This goes pretty fast.
sm
macmandigital.com
Old 01-15-2003, 10:59 AM
Sunking's Avatar
Sunking Sunking is offline
I'm pretty sure there is a Pluggo plugin that accomplishes this. You could check with them.
www.cycling74.com/products/pluggo.html
Old 02-11-2014, 12:52 PM
4stringsdave 4stringsdave is offline
I'm sure you've figured this out by now but try Drumtracker by Toontrack... thats what i've used for a while
Old 02-11-2014, 10:42 PM
JFreak's Avatar
JFreak JFreak is offline
deleted by me
Janne
Old 02-11-2014, 10:47 PM
Southsidemusic's Avatar
11 year old post so let's hope he isn't still looking for a plugin for this
Or ... Maybe he still looking
Best Regards
Christopher
South Side Music Group
WEBHOME
Old 02-11-2014, 10:51 PM
JFreak's Avatar
Exactly why I deleted my post, noticed that too late :) But if he was, he would be amazed in what is available today...
Janne
Old 02-12-2014, 08:05 AM
ddwhitney ddwhitney is offline
This is pretty much the only thing I use, it came out before many of the current options like Slate Trigger etc... for under $100.
http://www.masseyplugins.com/plugins/drt#plugins/drt
Digidesign 003R+PTLE 8.0.4 DV Toolkit 2, ASUS P5Q Pro P45, CPU INTEL Q6600 2.40G, CORSAIR DOMINATOR 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DR2 1066 (PC2 8500) ATI Radeon™ X1550 DIAMOND Stealth PCIe 1 Seagate Barracuda 320GB SATA Hard Drive (Root/Sys) 1 Seagate Barracuda 500GB SATA Hard Drive (Audio/Video) 1 PPA 80GB 1394 Firewire Oxford 911 PYRO PCI64R2 3 Port Firewire Card (PCIe) Antec 300 case. PSU ROSEWILL RP600V2-S-SL 600W,
Windows 7 64 bit.
Fixing an overly dynamic Kick or Snare track Alwyn Walker Tips & Tricks 8 12-29-2016 11:56 AM
Strike: Unable to bleed kick & snare into HiHat track? StinkyStan Virtual Instruments 5 05-30-2009 09:21 AM
How do I convert a live snare into a midi trigger? uno1234 Pro Tools TDM Systems (Mac) 2 06-16-2005 02:27 PM
converting kick and snare track to midi monkey MIDI 1 01-15-2003 11:18 AM
Triggering Kick and Snare in PT Using midi makerthemaker Pro Tools TDM Systems (Mac) 4 10-25-2000 10:26 AM
