Old 11-05-2010, 11:01 AM
edwinh edwinh is offline
Default PT 9 won't start up: could not initialize current playback device
This is on a MBP. I want to be able to use it with the built in hardware and I can't find any core audio drivers to install. I uninstalled PT, restarted, reinstalled, repaired permissions, installed 002 drivers, still no love.
Any ideas?
Macbook Pro M1 Pro
PT 2022.6
MH ULN-8 x3
Old 11-05-2010, 11:18 AM
Crypto Crypto is offline
Default Re: PT 9 won't start up: could not initialize current playback device
Any ideas?
I have the same problem on my iMac and Mbox 2 mini. I've also tried reinstalling both the software and drivers repeatedly and repairing permissions and removing all other plug-ins, but with no luck. I get the same message "Could not initialize current playback device" on all playback engine options (built-in and mbox 2 mini).
Everything is working fine on my MBP though...
Old 11-05-2010, 11:31 AM
gyom gyom is offline
Same here, on a MBP, 10.6.4, without any audio interface plugged in.
ProTools won't start up, telling me: "ProTools could not initialize the current playback device. Please make sure that the device has been configured correctly"
What am I missing?
Old 11-05-2010, 11:59 AM
audiomold audiomold is offline
Me as well. I bought it last night and have spent countless hours trying to get PT9 running.
Ive tried every trick in the book. This is extremely frustrating
Old 11-05-2010, 12:03 PM
smfelton's Avatar
smfelton smfelton is offline
I had no problems, I first did a complete uninstall then just installed PT9 full installer, it created an aggregate device of the MBP's i/o and it just worked, i did not use any other driver installer and i did not upgrade, I hope this helps.
 OSX 10.11.5, PT 12.5, iConnectAudio4+, Axe FX 2 XL+, Music Man Majesty
Old 11-05-2010, 12:14 PM
I downloaded the full install as well and did a clean uninstall of PT8. Ive even gone as far as removing all of my plugins to make sure one of them wasnt corrupt/incompatible.
Even with my 002 hooked up and the drivers installed i still get the same message.
"Pro tools could not initialize the current playback device. Please make sure the device has been configured correctly."
Where would i go to configure it correctly?
Old 11-05-2010, 12:21 PM
SessionKat SessionKat is offline
http://avid.custkb.com/avid/app/self...p?DocId=379411
maybe checking these can help?
-tv
Tim vdB
Avid Audio
"There's a fine line between stupid and clever."
Old 11-05-2010, 01:07 PM
Franquito112 Franquito112 is offline
I'm not seeing any problems. I installed PT9 on a clean 10.6.4 iMac and Pro Tools launched with the "Aggregate I/O" just fine.
Wow, no LE or Maudio device connected and I'm hearing my sessions with the built in speakers! This is so unreal!
Old 11-05-2010, 01:10 PM
FYI for Windows users!! You need to download ASIO4ALL if you want to use the built in audio devices.
http://www.asio4all.com/
Old 11-05-2010, 01:55 PM
Originally Posted by SessionKat View Post
Nope. Didn't help at all. I don't see how we can configure the program if the program won't open. I've done several clean uninstalls and reinstalls and still no progress. Clearly I'm not the only one with this issue. It would be helpful to be able to contact Avid, but after spending the money on the upgrade, I'm not in the mood to have to spend more money just to get it to boot.
Macbook Pro M1 Pro
PT 2022.6
MH ULN-8 x3
[IMG] code is Off
Pro Tools could not initialize the current playback device. Please make sure that the filattan macOS 3 11-01-2015 07:02 PM
Pro Tools could not initialize the current playback device (on 10.2.0) Cosme macOS 1 07-18-2012 06:45 PM
Pro Tools could not initialize the current playback device mkpascucci macOS 4 05-01-2012 04:00 PM
Protools cannot initialize current playback device......HELP!!!!! weedrock macOS 3 11-01-2011 07:47 AM
Pro Tools could not initialize the current playback device johnwesleybarker macOS 2 01-14-2011 05:52 PM
