Community Terms of Use
Google Search | Search Knowledge Base | Search Avid.com
Find Support | Pro Tools Support Videos | Support FAQ
Software Updates, Drivers, Manuals, Compatibility, Troubleshooting, etc. (Links)
Please post your message once only to the correct forum
Help us Help You - READ THIS Before Posting!
Pro Tools 11
Go Back   Avid Pro Audio Community > Legacy Products > Mbox, Mbox 2, Digi 001, Digi 002, 003 (Mac)
Old 10-29-2010, 07:15 PM
paul_g paul_g is offline
Default -10db +4DB switch on 003 I/O 5-8?
Question about the the -10 / +4DB switch on the I/O on 5-8 on Factory 003:
The diagram states that:
-with the button out it's +4 DB
-with the button in it's -10 db
When I press the button in, there is in an incredible amount of gain added to the input... I expect a -10 pad when I press the button in, instead it sounds like it's +4 db.
Did Avid (digi) reverse the little graphics on the back or am I missing something? This has perplexed me for a few years, finally getting around to asking the question.
Regards,
Paul G
2.4 ghz Intel Core 2 Duo iMac
OS: 10.7.5 (Snow Leopard)
4gb (667 MHz DDR2 SDRAM)
LaCie Audio Drive - FW800
DigiDesign 003 Factory PT10.2.0
PreSonus DigiMax FS
Old 10-29-2010, 07:29 PM
BRH BRH is offline
Default Re: -10db +4DB switch on 003 I/O 5-8?
This is correct, but in your mind you have it reversed.
-10 is for consumer gear line level (weak). It's not a -10dB pad.
+4 is for a professional line level (strong signal) It's not a +4 boost.
When you have it on the +4 setting it acts like a pad... about 12dB.
Old 10-30-2010, 07:56 AM
8068 8068 is offline
That's correct. The terms are sensitivity, meaning -10 switch is compatible with gear that puts out a signal that is 10 db lower then 0dB. The +4 switch is compatible with gear that outputs a signal that is 4dB higher than 0db.
This is similar to many gain settings on mic preamps. -50 is 50dB gain, 0 is 0dB gain.
The reason it is just shy of 12 dB and not 14 dB is because pro gear uses a different dB standard then consumer gear. ( dBm vs dBv )
Brad
Old 10-30-2010, 08:37 AM
BRH BRH is offline
That's correct.
Old 10-31-2010, 04:15 PM
Thanks for all the clarification - this makes sense.
p
PreSonus DigiMax FS
How do I know if I'm -10db or +4db? Badertime@hotmail.com Mbox, Mbox 2, Digi 001, Digi 002, 003 (Mac) 7 01-18-2010 02:40 AM
LFE 0db or + 10db for Dolby E AudioPostChris Pro Tools Post & Surround 6 02-10-2009 05:17 PM
192 -10db snake groovenix Pro Tools TDM Systems (Mac) 1 07-24-2006 09:34 AM
+4db / -10db question? Digitalkidd Mbox, Mbox 2, Digi 001, Digi 002, 003 (Win) 2 07-02-2006 04:26 PM
+4db to -10db? Ben Jenssen Mbox, Mbox 2, Digi 001, Digi 002, 003 (Mac) 14 06-27-2002 05:46 AM
