Old 10-29-2010, 12:30 PM
edadema edadema is offline
Banned
Default Auto Tune 7 even worse!! than EVO
I only upgraded to 7 because I get a Low Memory warning when I use more than 11 in a full session. I was praying that they fixed it. They didn't The new AT 7 is even worse.
On a empty session if I go beyond 22 tracks it will crash. Try for yourself
I emailed there support and have heard no response.
Here are some videos I made showing the errors and crashes
http://www.youtube.com/watch?v=AtIyavSqCUY
http://www.youtube.com/watch?v=H2PCzqOiPEk
Don't Buy!!!Don't Buy!!!Don't Buy!!!Don't Buy!!!Don't Buy!!!Don't Buy!!!Don't Buy!!!Don't Buy!!!Don't Buy!!!Don't Buy!!!Don't Buy!!!Don't Buy!!!Don't Buy!!!
Old 10-29-2010, 12:52 PM
formfunction formfunction is offline
Default Re: Auto Tune 7 even worse!! than EVO
Typically, to make good purchases, a little more research than that is prudent.
Old 10-29-2010, 01:04 PM
Memory usage will depend on 2 Option settings in AT7, have you tried changing the values?
Personally I always tune manually phrase by phrase and record any tuning I do, so I would never need that many instances of a correction plugin to be instantiated.
Any plugin which exceeds the hosts RAM space will cause a crash.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 10-29-2010, 07:34 PM
smpkeys smpkeys is offline
Did the latency get better at all on 7? When I upgraded to EVO, I found that it was impossible for me to use in real time because of latency - Real time meaning I wanted to put it on a lead vocal set on auto for a BGV singer to add parts to. I ended up just going back to AT 5 for these situations.
2010 Mac Pro, 3.46 GHz 6 Core Xeon,32 GB RAM, OSX 10.9.5, PT 12.4, RME Fireface UFX, Command 8, Mytek 8x192, SSD evo on System,Audio&Samples on spinner drives WD SATA 64mb Cache
Old 10-29-2010, 07:35 PM
oops - sorry, thought I was in the LE forum. I assume my above problem is a non issue with HD using ADC?
Old 10-29-2010, 09:13 PM
Tom Hartman Tom Hartman is offline
Personally I always tune phrase by phrase and record any tuning I do, so I would never need that many instances of a correction plugin to be instantiated.
Rail
But if you have 16 tracks of backing vocals that all sound fine in "cruise control" mode it's a great thing. I'd be on a song for a week if I had tune each of those tracks individually.
I had about 8-10 Autotunes open today with no problems though.
TH
Old 10-29-2010, 10:43 PM
TOM@METRO's Avatar
TH
You can still bounce the "cruise controlled" tracks and inactivate and hide the AT7 tracks just in case you ever need to change them. Or AudioSuite them if you're sure.
~ tom thomas
Formerly hobotom
Pro Tools HDX~HDN 2018.4
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 10-29-2010, 11:57 PM
studiojimi's Avatar
studiojimi studiojimi is offline
too many potentialities for train wrecks that way.
that kinda defeats the idea of having a thing called a plug in.
CAZADOR RECORDING
PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2
With GOD as my partner. . . I need to make my plans LARGER.
Old 10-30-2010, 12:04 AM
Banned
I posted some video on you tube to show you how easy it is to crash Pro Tools with Auto Tune 7. I get about 20 for a empty session. The other video is the critically low memory. I get about 11 or 12 before that happens.
Now if they said you get about 10 to 12 in a full session. Or This plug in will make all your sessions unstable. Would you ever buy this plug in. No. I used to get 40 plus with Auto Tune 5
Old 10-30-2010, 12:47 AM
pidge pidge is offline
TH
why would you even bother recording 16 out of tune tracks???
i have a simple phrase you need to learn... "Yep, that was great!! but lets do it again...."
Waves Tune and Auto-Tune Unhappy With HDX? Logichead Pro Tools HDX & HD Native Systems (Mac) 2 11-25-2012 11:42 AM
"Auto Rename" regions BUG ? IT GETS WORSE!!! 25ghosts Pro Tools TDM Systems (Mac) 15 03-30-2011 07:25 AM
vocal tune with Auto Tune 5 martin coria Pro Tools M-Powered (Win) 17 08-06-2010 09:14 AM
Upgrading Auto Tune 4 to Auto Tune Evo summit01 Pro Tools TDM Systems (Mac) 0 10-16-2008 11:05 AM
Auto-Tune 3 PT 7?? zeeman Pro Tools TDM Systems (Mac) 3 01-13-2006 10:53 AM
