Old 09-23-2010, 06:32 AM
kaczor954 kaczor954 is offline
Default ProTools 8 hardware requirements
Is ProTools capable of utilizing multiple cores?
I'm creating configuration for Windows 7 64bit Proffesional machine, which is supposed to run ProTools and I wonder if it makes sense to put 4 cores CPU (or maybe 2x 6cores).
Another question is how often ProTools reads/writes HDD? Does it make sense to build fast RAID 0 array or is it better to put more RAM into ProTools box?
Best regards,
Kaczor
Old 09-23-2010, 11:37 AM
Dism Dism is offline
Default Re: ProTools 8 hardware requirements
Originally Posted by kaczor954 View Post
Yes.
Best regards,
Kaczor
Pro Tools is not compatible with RAID. More RAM can never do you wrong, especially in a 64 bit environment. While Pro Tools itself is not yet 64-bit, having extra RAM will free up resources for the OS. Plus, you can host your VIs outside of Pro Tools to take advantage of 64 bit address.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 09-27-2010, 01:05 AM
My question is how many cores ProTools can use. Is it scalabe to as many cores I have or does it use only 2 cores.
How come ProTools doesn't support RAID, when RAID is transparent to whole operating system and matrix is visible as normal hard drive.
Please tell me what read/write speeds are typicall.
Old 09-27-2010, 07:01 AM
Pro Tools will utilize however many cores you have in your system, including virtual.
RAID isn't entirely transparent if it is internal. It's also not really necessary, nor as reliable as claimed. Making regular backups is far safer.
There aren't really any "typical" read/write speeds for Pro Tools, as it's entirely dependent on the user. How many tracks/plugs/VIs/samples you're using will affect disk performance in various ways.
D
Old 09-27-2010, 09:29 AM
BaileyBass BaileyBass is offline
Depends on how you make the backups.
As far as not being necessary... RAID would be a time saver if it were "approved", although I know folks using it just fine with no issues. SB
Old 09-28-2010, 01:43 AM
I was considering RAID as a way to increase disk performance. I'm just worried that single hard driver may be to slow. Are my worries reasonable?
Old 09-28-2010, 05:33 AM
barstool719 barstool719 is offline
honestly, no. a high quality 7200rpm, < 11ms seek time SATA hard drive will do just fine. if you have a desktop machine, just add more internal drives.
i prefer seagate barracuda and hitachi deskstar drives, others will have other favorites.
avoid any hard drive labeled as "green" - the power saving functions are not suitable for Pro Tools
RAID isnt really all its cracked up to be reliability wise, and is completely unsupported by PT
i7-860 / 12GB Kingston / Intel DP55WB / 500GB Barracuda / 1TB Deskstar W7x64
Focusrite Saffire Pro 40 / Pro Tools 9.0.3
Mics, Guitars, Amps, Basses, Drums, Keys
http://overtheeffect.bandcamp.com
ProTools 11 hardware requirements raducanmihai Pro Tools 11 6 08-28-2013 12:07 PM
Hardware interface requirements for protools version upgrade Amnesiac 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 01-25-2008 08:23 AM
hardware requirements confusion - help! Park Seward 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 09-19-2001 07:33 AM
5.1 Hardware Requirements & what systems to buy nodell General Discussion 11 11-09-2000 06:48 PM
Digi 001 Hardware Requirements garyinfante 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-13-1999 12:01 AM
