Old 09-15-2010, 10:20 AM
Default Fast paning weirdness
Try this:
-Create a mono-track bussed to an LCR-output.
-generate a piece of pink noise (or use some other static test signal)
- draw in a linear pan from fully left to fully right across the LCR over about half a second in time.
now shorten the pan duration by nudging the breakpoints closer together and listen to the result.
Hereīs whatīs weird. On my system the pan sounds chopped up and not smooth as soon as I make the pan shorter than 9 frames.
Can someone verify this? Is this a bug or a feature?
I have some very quick car-bys on screen that are impossible to pan using PTīs pan automation because they start sounding completely wrong and irregular when they are below 9 frames (@24fps ruler).
Any ideas how I can work around this restriction? The strange thing is that when the pan sounds bad (at 7 frames for example) and I play the session at half speed (shift-space bar) the pan being played is still chopped up allthough now being played over a period of 14 frames. When I create a 14 frame long pan and play that in real-time it sounds fine.
So far Iīve found no way to get smooth very quick pans in PT. How do other people do this?
Thanks,
Frank.
EDIT: I just found this thread on the same issue: http://duc.digidesign.com/showthread.php?t=261571
But if itīs because of amplitude modulation, why the flip is PT still playing the fade with all the level drops when you play back at half speed. Makes no sense to me.
PTHDn 2019.12 (OSX10.14.6), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM, Xilica Neutrino, Meyersound Acheron
Old 09-15-2010, 10:42 AM
nucelar's Avatar
nucelar nucelar is offline
Default Re: Fast paning weirdness
Does not happen here (LE 7.4)
Weired.. Have you tried adding extra breakpoints inbetween?
Edit: Duh, I tested it with regular stereo. Nevermind
Old 09-15-2010, 10:48 AM
tilman tilman is offline
itīs funny. I tested it while I was in a 96 KHZ session. there the problem
became noticable at 4 frames. now opened a 48 kHz session
there it occurs at 7 or 9 frames.
So I guess the soloution is to work at higher samplerate.
I tested LCR on Protools 8.03 LE Complete Prod. Toolkit
Old 09-15-2010, 11:02 AM
Hm. So Iīm going to tell the re-recording mixer that all the car bys are in a seperate session and he has to switch the studio to 96k to be able to continue the mix?
Not sure about that.
Seriously: I think itīs a bug, no?
I always thought that if thereīs one thing thatīs easier and more precise to do in a DAW than on a console itīs fast pan automation. Seems like I was wrong. I guess Iīll have to leave to panning to the mixer. Luckily the film is not being mixed on PT ;-D
Frank.
Old 09-15-2010, 11:10 AM
automation and a lot of plugin stuff perform a lot better at higher samplerates.
seems that the resoloution of protools automation is tied to the sessions samplerate. I bet some other daw programers have implemented more resoloution in their daw automation!
I would check it out! I persume if you do this in a 192 kHz session it will be even less frames before this negative effect appears.
but the answer in the other thread is wrong this has nothing to do with
amplitude modulation.
Old 09-15-2010, 11:12 AM
so what I mean is when the sword fight comes he should switch to 192 kHz.
I bet this glitch exists in every protools version!
Old 09-15-2010, 11:27 AM
FlorianE FlorianE is offline
Frank,
have you tried to bounce your panned cars to another track in half-speed record? Fast automation issues can sometimes be 'bypassed' that way.
Cheers
Florian
Old 09-15-2010, 11:45 AM
Originally Posted by FlorianE View Post
Frank,
Cheers
Florian
Florian,
problem is that when you play a 7-frame pan at half speed (resulting at 14frames) PT will still play back the pan with multiple level drops. You can try it yourself.
(see my first posting)
Frank.
Old 09-15-2010, 01:34 PM
other workaround would be some 3 CH panorama plugin by a third party developer
Old 09-15-2010, 01:56 PM
Postman Postman is offline
Adding extra break points makes a HUGE imporovement. I'll post some screenshots and come back here with a link.
HTML code is On
New PT10 User. MBox3, MAudio Fast Track Ultra, MAudio Fast Track 8R? epu Pro Tools 10 3 06-13-2012 03:55 PM
digi 001 nor paning right?? broken81 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-26-2006 08:37 AM
IR/1 weirdness jeff markham Pro Tools TDM Systems (Win) 6 09-01-2006 12:54 AM
Paning a stereo channel rodrigo21 Tips & Tricks 2 05-31-2005 07:39 AM
Surround Paning on C24 blairl ICON & C|24 5 07-06-2002 07:36 PM
