Old 09-08-2010, 11:03 AM
ZDF ZDF is offline
Default MBOX2Pro won't power on anymore!!
Hey all, thanks for your help! Yesterday my mbox2pro worked like a charm, today no power, i've tried everything. This is my chain:
Mbookpro-500G Seagatefirewire800HD-firewire800/400adapter-Mbox2pro
I'm going to try to reinstall PT but avoid the 8.0.4 update in case that might be the issue...
Z
Old 09-08-2010, 01:07 PM
Dism Dism is offline
Default Re: MBOX2Pro won't power on anymore!!
Z
No need to create multiple posts... just bump the same one.
We're gonna need more info.
Are you using the power adapter for the MBox? Which Macbook Pro model? Pro Tools version? OSX version?
Next...
Particularly for the MBox2Pro... there have many been reported issues with your setup. Running 800->800 then 800->400 can result in issues, because the hard drive in the chain may not be dropping the bus speed properly. This can be the result of firmware issues, among other things.
Ideally, you want a FW400 drive.
Macbook -> 800->400 cable -> Drive -> MBox
Keeps the chain consistent, and less room for error. If your Macbook has an ExpressCard slot, you'd be better off getting a FW card, and keep the drive and MBox on completely separate busses.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 09-08-2010, 02:11 PM
ZDF ZDF is offline
Thanks so much for your help! I thought my rig info would show up. Anyway, here's what I'm using:
MacBookPro i7 2.66ghz with 4G ram OS X10.6.4 using PT LE 8.0.4
I AM using a daisy chain from the Macbook to the FW800 HD then to the Mbox2pro using a 800/400 adapter. If there is a history of problems with this setup, I might need to change it up. I am NOT using a power adapter as I thought it would be easier(one less thing to plug in) to power the Mbox with the FW.
Is this the probable cause for my issue?
Old 09-08-2010, 02:38 PM
Will Russell's Avatar
Will Russell Will Russell is offline
First question. If you connect the MBox2PRO directly to the computer with the FW800-FW400 adapter, does it power up?
Second question. Do you have another cable/adapter to try?
Will Russell
Electric Wilburland Studio
https://linktr.ee/wilburland
M1MAX Mac Studio OS 14.4.1, PT2024.3, HDX, S1/Dock
M1 PRO MacBook Pro OS 14.4.1, PT2024.3, BabyFacePro FS
Old 09-08-2010, 03:05 PM
ZDF ZDF is offline
Yep, I've tried a different cable, different adapter, straight into the macbook, daisy chained, etc. I've tried reinstalling PT and only installing PT 8.0.3, and still no love from the mbox. I'm on the road so I won't be able to try the actual wall wart until I get home.
MBox Pro 3 appears to have died. Won't power on anymore. Damallooo FireWire & USB Audio Interfaces (Mac) 3 04-06-2013 11:38 AM
PT 9 on 64 bit W7 mbox2pro whitewaller Windows 2 05-02-2011 12:39 PM
Mbox2Pro - No Power via FireWire izzumm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-28-2008 01:00 PM
audible headphone pops at Mbox2Pro power up? DaveBCC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-09-2007 10:25 PM
Mbox2Pro gh4life 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 11-18-2006 09:42 PM
