Old 08-19-2010, 04:20 AM
peter99 peter99 is offline
Default files missing...
I´m just mixing a project and on some of the songs I get the message ...audio files are missing... would you like to search..skip etc.
there are NO files in the session missing so it must obviously be some files in a undo memory or something - when I go to regions, select unused and remove them I still get this missing message when opening the session
SO: is there a possibility to erase all undo memory stuff?
Old 08-19-2010, 04:26 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: files missing...
Just to check. when you select unused and then remove them, are you then saving the session with an incremental number "song name 3" etc from song name 2.
It usually happens when files have been deleted from another session that were used in this session etc.
failing all that after removing all unused, use save copy in to create a new session
Chris
Producer, Engineer,
www.ukmastering.com
Old 08-20-2010, 02:11 AM
ok I´ll try to save copy as but am I right I have to copy all audio files as well? because I dont like copying audio too many times...
Old 08-20-2010, 10:27 AM
formfunction formfunction is offline
Old 08-21-2010, 10:14 AM
ok I deleted all unused playlists and again I deleted as well all unused audio files, did a safe copy in with all audio files and everything and still get the message some audiofiles are missing
I dont know what to do...
please help
thx
Deleting files from clip list and missing files colinato Post - Surround - Video 1 10-22-2013 09:52 AM
Missing fade files, missing audio in resaved sesssions drygruo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-14-2010 04:56 PM
All Sessions using SDII files are missing all audio files and won't relink bigmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 03-18-2009 12:54 PM
missing audio files are actually not missing tomcat Pro Tools TDM Systems (Mac) 3 12-24-2006 02:25 PM
Missing Fade files become missing audio files? Tim R. Pro Tools TDM Systems (Mac) 11 06-21-2004 09:48 AM
