Closed Thread
Old 08-06-2010, 12:26 PM
Avid's Avatar
Avid Avid is offline
Thumbs up Eleven Rack Firmware Update Version 1.0.3
Downloads and Release Notes:
Also available from the Eleven Rack product section, at the lower part of the "More Resources" tab:
Eleven Rack Resources
Eleven Rack Firmware Update v1.0.3 Release Notes — August 5, 2010
These downloads contain the Eleven Rack Updater application and a Read Me describing the installation process and what's included in the update.
What's New in Firmware Version 1.0.3
  • Fixed noises coming out of FX Loop when switching between Rigs or activating the Tuner
  • Fixed an issue in which Eleven Rack would not boot into the user-selected Display Mode
  • Fixed an issue in which the knobs in the 'Outputs' display mode could go blank if the amp model was changed in the Pro Tools guitar window
  • Fixed an issue with Amp tremolo controls becoming unresponsive when assigned to pedal control (MultiFX mode)
  • Improved control knob tracking, minimized incidents of false parameter value changes
  • Improved Tuner responsiveness and feel
  • Improved response and model specific configurations for external expression pedals
  • Added the ability to switch Rig Inputs between the guitar and mic or line inputs using MIDI CC messages
For additional details, please see the Eleven Rack Firmware Update v1.0.3 Read Me, included with the downloads and available separately.
Who Should Use the Eleven Rack Firmware Update Version 1.0.3?
All Eleven Rack users are encouraged to update to the latest firmware version. Make sure your Eleven Rack unit requires this update by checking the currently installed firmware version number (see Read Me for instructions).
Please Note:
We will also be releasing a version for Windows 7 64-bit shortly. For those on that platform, you can use the 32-bit version for now. Just be aware that the 'Update' button will look grayed out and the device will appear to be offline...just hit 'Update' anyway and it will work fine.
Rock on!
Eleven Rack Team
Avid Audio
Closed Thread
Eleven Rack Firmware Update v 1.0.3...now! TheChimp Eleven Rack 77 03-14-2012 11:20 PM
Eleven Rack Expansion Pack Firmware 2.01 Update fails on Mac OS X Lion DigiTechSupt Eleven Rack 0 10-17-2011 05:16 PM
Eleven Rack Firmware Update issue - Windows Vista felipenoris Eleven Rack 23 03-15-2011 10:05 AM
Eleven Rack Firmware Update Version 1.0.3 Avid Technical Alerts 0 08-06-2010 11:50 AM
Eleven Rack Firmware Update Version 1.0.2 Avid Technical Alerts 0 03-03-2010 11:45 PM
