Old 07-19-2010, 12:18 AM
NGokhool NGokhool is offline
Default Markers (memory locations)
Hi there all
first time posting so please be gentle :)
Im a sound design student and I normally spot my sessions in protools 8 LE using the markers (memory locations) i was wondering if there was a way to print out the memory location list to give u a cue list of where you have your markers with time code this would be useful in foley or adr. in fact any application of pro tools were spotting is required.
I have read the manual and it doesn't seem to mention it at but if any one knows any different please drop me a line and do so as well if this isn't true and im just making a fool of my self :)
all the best
Nathan
Old 07-19-2010, 05:54 AM
priorytools priorytools is offline
Default Re: Markers (memory locations)
Allo Nathan.
Dude. .
Firstly. . LE doesn't display time code unless you buy the video tool kit .
Secondly . To "spot" audio in PT. . Use wav files. . Import the audio & select "spot" as opposed to "slip" or "grid". . This will snap your files to the position at which they were recorded. . Read the manual. .
Third; printing a list of your marker points . . Easiest way is to do a screen grab of the memory locations window ( cmd 5 ) . I think you can configure that window to display various info. . Again, read the manual-chapter 34.
Bon chance.
~ Trashcan Mac Pro late 2013 - 64 GB RAM - 10.11.6 / Pro Tools HD 12.6.1 / HDX 2 + UAD2 PCIe OCTO in Magma Expressbox 3T / HD I/O's x 4 + 1 x 96io / Avid S6 M10-24-5 V3.6 ~
~ MBP 15" 2.8 Intel Core i7 -10.12.5 /Apollo 16 / Steinberg U22 / Artist MIx / Pro Tools HD 12.6.1 - UAD2 V8 / UAD2 Satellite DUO ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / HEAT / Magma PE6R4 / ProControl 24 faders / UAD2 QUAD PCIe ~ ARCHIVE RIG
Old 10-07-2010, 09:49 AM
florian.ardelean florian.ardelean is offline
Originally Posted by priorytools View Post
Allo Nathan.
So? Does Spot only work with timecode?
Sorry but you're off-topic. The man clearly states he needs to spot regions for ADR or FOLEY, which means that the project he will be importing into has a different timecode than the project he recdorded it into. He may even record using a portable device. And he said he read the manual.
Your solution is quite complicated. For instance, I recieve print outs with the memory locators from AVID Media Composer, for, say, where the video editor wants me to put certain sounds. Why? Because I can't import them as markers.
And in Pro Tools, where I add a different marker for each sequence of a TV series (which needs a different ambience background). I'd like to print out those memory locations so I can have them on a sheet, which I can use to keep track of what sequences I already edited.
Is there a way to do that? Export memory locators as text (like in Avid Media Composer) would be useful.
Old 11-03-2010, 09:58 AM
I found a great way to export markers!
A neat little program called EdiMarker, compatible with Mac and PC (donationware) which will export Memory locations to a text file, provided that you export a MIDI track from ProTools (be it even empty)
The text file can then be imported into ms Excel or openoffice Calc (freeware) to make a nice table with whatever else you need, and print it out.
Thanks to Mark Franken
Here's the link:
http://www.soundsinsync.com/index.ph...133&Itemid=102
Old 11-03-2010, 11:25 AM
AfterJohn AfterJohn is offline
I'be done this by "Export Session Data As Text" before...I think, it's been a while.
MacBook Pro 2.2 GHz Core i7 4GB RAM 10.8.5, PT 10.3.4, Waves v9.1, Duet 2
redtuxedo.com
milkmoneyconsulting.com
mindexpansiontechnology.com
Old 11-03-2010, 01:38 PM
daeron80 daeron80 is offline
Priory is right about one thing - you'll have no time code support in LE at all without the DV Tool Kit.
Nice to know about the EditMarker utility. It's still a hefty workaround. As much as PT is used in post, it's a shame they've never added the ability to print straight from the Markers window. Dumbfounding oversight.
David J. Finnamore
Nyquist was right.
PT 2018.x HD | Omni | macOS Sierra
PT 2018.x | Saffire Pro 40 | Win10
Old 12-11-2010, 03:04 AM
jbep jbep is offline
Here's a trick someone might want to explore:
I have often used a midi track, set to view blocks, for comments on tracks, by creating midi blocks and renaming.
It's like markers but more specifically timebased, color-codeable, length editable, more than one layer (track) of comments possible. etc. a little fiddly but whatever.
So i tried Export session data as text, to see if these midi markers would show up, but they don't.
So i just tried making an audio track, and inserting a blank audio region, then moving the regions and naming them for comments. this does then show up in session data export and looks like this:
TRACK NAME: NOTES AUDIO
CHANNEL EVENT REGION NAME START TIME END TIME DURATION
1 1 Note only 10:50:16:04 10:52:21:16 00:02:05:11
1 2 this is good 10:57:59:15 10:59:33:01 00:01:33:10
1 3 THIS sux 11:11:26:12 11:12:50:18 00:01:24:06
in case that's interesting to anyone.
Old 12-12-2010, 07:09 PM
Clever.
David J. Finnamore
Nyquist was right.
Old 02-09-2014, 07:17 PM
literatemoose literatemoose is offline
In terms of keyboard shortcuts, Command+Keypad 5 (or Control+Keypad 5 on PC) will bring up a small window within Protools that will give you a list of your markers. Click on the items in your list, and it will take you to the time as well. Not a perfect solution, but it might be a start?
Memory Locations/Markers GTBannah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 10-20-2008 08:56 PM
Selecting Between Markers or memory locations wwilentz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-30-2005 11:51 AM
Markers (memory locations) (ProTool HD 6.9.2) Jano Vesta Pro Tools TDM Systems (Mac) 5 09-06-2005 08:01 AM
Memory Locations / Markers not showing up in PT6.4 TWoZ Post - Surround - Video 1 10-19-2004 10:07 AM
Markers / Memory Locations not showing up in PT6.4 TWoZ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-19-2004 10:05 AM
