Old 07-08-2010, 03:51 AM
fup4000 fup4000 is offline
Default how to midi korg triton with pro tools
Hi all,
im new to the hardware software thing..& if this has been covered here b4 i'm sorry...
but "How to midi korg triton with pro tools"?? 003
TIA
FUP
Old 07-08-2010, 04:32 AM
lincol1 lincol1 is offline
Default Re: how to midi korg triton with pro tools
You might need to expand on what you are trying to do a little - but essentially...
On the Triton connect midi in/out to 003 out/in.
Run a balanced cable from triton to 003.
Make sure midi thru is selected in PT.
If you want to play sounds from the Triton that are sequenced from PT;
Monitor the Triton via an Aux input assigned to the physical inputs where the Triton is connected.
Assign a midi track's in/out to the midi port on the 003.
You can also use the Triton to control VI's inside PT.
Lincoln
Lincoln Mitchell
www.studiofifty.net
Mac Pro 2.66 Ghz Quad, 10.6.6, 12GB Ram, PT9, Logic 9, Kontakt, East West, VSL, Waves, Sound Toys, IK Multimedia
RME FF UC, Focusrite Octopre mkii, UA LA 610 mkii, MC Transport, Yamaha HS80M, Lauten, AKG, Sure, Blue
Old 07-08-2010, 06:00 AM
Sorry & Thank You...
Lincoln
FUP
Using Korg Triton via MIDI in PT DeeMee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-28-2007 10:19 PM
Recording MIDI into Pro Tools from Korg Triton Sean1212 Tips & Tricks 3 07-30-2005 07:40 AM
korg triton, 002: MIDI setup.......please help!!! woodbeatz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-15-2004 04:57 AM
PT 6.1 + Digi 002 + Korg Triton.....need midi help madmaxhk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-22-2003 04:27 AM
What is the Offset value for a Korg Triton midi to pT Hardnox Pro Tools TDM Systems (Mac) 0 07-11-2001 10:12 PM
