Old 06-30-2010, 03:42 AM
crizdee's Avatar
crizdee crizdee is offline
Default Any apps for reading ISRC codes on Snow Leopard?
i'm looking for something quick and easy to check the ISRC codes after they have been written!
Got one client says the codes are not on the CD i burned using Toast 9. i haven't checked for a while and no one else has come back saying the codes are not present. but i'm wondering if there might be a problem with the Sony optiarc burner and toast on snow leopard, as i've just switched to using Snow Leopard.
Chris
Producer, Engineer,
www.ukmastering.com
Old 06-30-2010, 04:04 AM
DetroitT's Avatar
DetroitT DetroitT is online now
Default Re: Any apps for reading ISRC codes on Snow Leopard?
Hi. The terminal will do this. (
drutil info)
I'm in Leopard although I wouldn't think it's changed.
TC
Terminal open
Have disc inserted
Open Terminal (Utilities)
type in: drutil subchannel (This will take a moment for all tracks. Command period will stop if you wish to check track #1)
Additional drutil commands are:
(i.e. Type drutil and the below command)
atip Displays ATIP information about inserted CD-R/RW media.
bulkerase Bulk erases -RW media in either quick or full mode.
drutil bulkerase (quick | full)
burn Burns a given file or directory to disc.
drutil burn (burn-options) <path>
cdtext Displays CD-Text present on an audio CD.
discinfo Displays disc related info when media is present.
dumpiso Parses ISO-9660 directory structures.
drutil dumpiso <devnode> <block> [format]
dumpudf Parses UDF directory structures.
drutil dumpudf <devnode> <block> [format]
eject Ejects media from the drive (if any).
erase Erases -RW media in either quick or full mode.
drutil erase (quick | full)
filename Translates filenames for different filesystems.
drutil filename <name>
getconfig Displays current and supported device features and profiles.
drutil getconfig (current | supported)
info Displays detailed information about connected drives.
list Lists all connected burning devices.
poll Constantly polls and displays device notifications.
status Displays detailed information about inserted media.
subchannel Displays subchannel (MCN, ISRC) info when CD media is present.
toc Displays TOC information about inserted CD media.
trackinfo Displays track related info when media is present.
tray Opens and closes drive tray, and ejects media.
drutil tray (open | close | eject)
version Display the OS and DiscRecording version numbers.
Old 06-30-2010, 04:39 AM
James Drake James Drake is offline
drutil subchannel | grep ISRC
Old 06-30-2010, 09:02 AM
Originally Posted by crizdee View Post
Chris
Toast will read them quick and easy - just go to Recorder->Disc Info
best,
rich
http://www.richbreen.com
Mac Studio / Sonoma, PT Ultimate 2024.10.1. HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
ISRC codes and other problems seek 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 08-19-2010 01:37 PM
ISRC/UPC/MCN codes? CD Text? EGS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-18-2006 06:47 PM
ISRC CODES volume9 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-19-2005 01:10 PM
ISRC codes poppy Pro Tools TDM Systems (Mac) 1 04-06-2004 11:07 AM
ISRC codes not reading Danny Caccavo Digidesign Hardware & Software 1 07-10-2001 01:30 PM
