Old 06-26-2010, 11:57 AM
Undertones Undertones is offline
Default How do I automatically insert a plugin on all tracks at the same time?
I want to use ATA on all tracks, first in the chain. How do I do this without manually adding the plugin on the first insert bar each time?
Old 06-26-2010, 12:30 PM
Kobra Kobra is offline
Cool Re: How do I automatically insert a plugin on all tracks at the same time?
Hold down the option-key when inserting the plug.
If you want, you can select all the tracks that you want the plug on and hold down shift+option.
Macbook Pro 15" 2.66 i7, 8GB RAM / 10.11.5 / Pro Tools 12 / Komplete Ultimate / EWQLSO Gold Play Edition / Steven Slate Drums / Logic Pro / Apogee Duet
Old 06-26-2010, 01:35 PM
Top Jimmy's Avatar
Default Re: How do I automatically insert a plugin on all tracks at the same time?
Just know that if you insert the first one on a mono track, it will only put them on the mono tracks. Ditto for stereo tracks.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Sierra 10.12.6.
Pro Tools HD 2018.3, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Old 06-29-2010, 01:21 AM
Stiff Stiff is offline
... And if you only want it on most of the tracks (i.e. not master fader for example) select the tracks you want it on and hold down shift+option.
Daily news & reviews
www.ProToolerBlog.com
insert time Macsearcher Pro Tools Software (Mac) 2 08-15-2013 06:51 PM
How do I automatically assign inputs and outputs of new tracks Johnrg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-19-2011 12:26 AM
New tracks are automatically in ticks mode, how to change? ibvee Pro Tools M-Powered (Win) 1 10-30-2007 07:06 AM
Tracks automatically unmute on playback..... dbsoundcheck Pro Tools M-Powered (Mac) 2 08-13-2007 07:10 PM
How to insert time / insert measures, without upsetting tempo map and markers imp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-25-2003 05:45 PM
