Old 06-09-2010, 07:06 PM
FunkTools FunkTools is offline
Default Can't Mute or Change Volume on Audio Track and Instrument track
One is a MIDI track on PRO TOOLS LE that I could only mute by making it inactive.
The other is a stereo audio track; a frozen version of the midi track. I mute it, pull down the fader, and it won't stop playing at full volume, even if I change it to outputs I don't even have.
any help appreciated.
Old 06-09-2010, 07:57 PM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Default Re: Can't Mute or Change Volume on Audio Track and Instrument track
That means its not what ur hearing playback & u can't make a midi track inactive so I'm not sure what ur doin...
btw, WELCOME TO THE ADAUCF
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 06-09-2010, 08:56 PM
ameristos ameristos is offline
can you still select it at all, anywhere? i.e. "solo" or drag it into a different order?
if not, i had this happen after installing some waves plugins. once i found the bad plugin and removed it, everything went back to normal...
just a thought. might not be the fix to your problem.
good luck.
Old 06-10-2010, 04:40 AM
Gothboy's Avatar
Gothboy Gothboy is offline
[QUOTE=FunkTools;1621953]One is a MIDI track on PRO TOOLS LE that I could only mute by making it inactive.
QUOTE]
Check the automation lanes to see if theres any nodes in there causing this.
Apple Mac Pro 2.88 GHz. Intel Xeon Quad core
16 GB RAM
Mountain Lion 10.8.5/El Capitan 10.11
Focusrite Saffire Pro 40
Ableton Live 9/Presonus Studio 3
I no longer use Pro Tools and just as happy!
Instrument track picking up my microphone, but not my audio track. raddster Pro Tools 9 5 01-20-2012 04:11 PM
instrument track volume peaks when instrument volume knob is down deadvisions 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-12-2011 01:43 PM
Problem Converting Instrument Track to Audio Track Gorbies 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 06-02-2009 09:11 PM
Can't mute Instrument track Gothboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-08-2009 10:33 AM
Mute on audio track switches off when I play the track el biciclista Pro Tools TDM Systems (Mac) 3 07-29-2003 10:54 AM
