Old 06-08-2010, 04:26 PM
GloryIsSilent GloryIsSilent is offline
Default file rename after the fact?
So i have a session with lots of files/regions named mono-1-03 and such. Is there a way to rename all those files and regions to confer to the track they are currently occupying, or any similar batch rename to more sensible naming convention?
Old 06-08-2010, 05:03 PM
Stig Eliassen's Avatar
Default Re: file rename after the fact?
You can use Auto Rename from the Regions list menu.
Old 06-08-2010, 05:17 PM
Top Jimmy's Avatar
Another idea could be to consolidate your tracks and rename the resulting regions however desired.
James Cadwallader
Old 06-08-2010, 05:30 PM
That's my suggestion too. Once each is consolidated, just double-click on a track/region to bring up the renaming window.
Old 06-08-2010, 05:49 PM
I need to look this up, thank you
Old 06-09-2010, 03:00 AM
If there's only one region on each track I would rename the track, then select the region and consolidate. The new region will reflect the new track name.
If there's several regions on each track I would use Auto Rename. Doesn't matter if you rename the track before or after you rename the regions, since Auto Rename doesn't reflect the track name, which BTW I find really lame.
Rename Audio Region and File - where go? smc917 macOS 2 09-16-2011 09:54 AM
Batch rename file types? jonnyrocker Pro Tools TDM Systems (Mac) 4 04-22-2006 03:17 PM
How To Rename Session file to work on PC? lowaters 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-27-2004 09:08 PM
rename file ZEUSS Pro Tools TDM Systems (Mac) 9 11-12-2003 01:40 PM
can't duplicate/rename file bluemt Pro Tools TDM Systems (Mac) 3 03-13-2001 01:30 PM
