Old 06-08-2010, 08:59 AM
teacherman teacherman is offline
Default Removing Vertical Grid Lines while in Slip Mode
PT 8.0.1 cs2.
Anyway to remove/disable the the vertical grid lines while in Slip Mode (like it was in earlier versions of ProTools?)?
thanks,
Old 06-08-2010, 12:21 PM
Stig Eliassen's Avatar
Default Re: Removing Vertical Grid Lines while in Slip Mode
Page 446 in the reference guide.
Old 06-08-2010, 12:22 PM
Eric Seaberg's Avatar
Eric Seaberg Eric Seaberg is offline
They're either there all the time or they're not, I don't think they disappear in Slip Mode. There's nothing wrong with having them there during slip, as they're only a visual reference.
Eric Seaberg • San Diego, CA
A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S.
Old 06-08-2010, 01:32 PM
Yes, Thanks PT LOVER. You are correct. Thanks for the tip.
Grid Lines in Slip Mode 9.0.5? anackman macOS 3 09-15-2011 04:24 PM
Slip to Grid mode no visual grid unless pressing "grid" mgoorevich Pro Tools 9 5 11-13-2010 08:11 AM
Grid mode, shuffle mode, spot mode and slip mode. RogTaylor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-24-2010 11:30 AM
Grid Lines - Slip Mode vs. Grid Mode Mt.Everest Pro Tools TDM Systems (Mac) 24 02-20-2006 09:38 AM
Can not see the vertical lines in grid mode Rifpop 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-12-2004 11:51 AM
