Old 05-27-2010, 02:57 PM
Strebor24 Strebor24 is offline
Default PT says "iZotope_Radius_Win32.dll" missing but I don't have it
This is the first time that I have tried to open PT 8 LE (Windows) since installing a Novation SL MKII (with Automap 3.4.1)
During start up I get iZotope_Radius_Win32.dll missing and PT will not open.
I didn't know that I even had Radius, it does not come with PT 8 LE that I am aware of, so I cannot just re install it.
Does anyone have any ideas as to what to do?
Also, I don't see Radius listed as a plug-in in Automap
Shuttle PC, XP Home SP 3, Core 2 duo 3.16 GHz, 4gb PC6400, 500gb SATA 3G HD, Mbox2 pro., Pro Tools 8.
Old 05-27-2010, 03:31 PM
77pro 77pro is offline
Default Re: PT says "iZotope_Radius_Win32.dll" missing but I don't have it
Check this thread I made some time ago and see if it helps.
Radius was licensed by Avid as part of Elastic Audio.
Hope this helps
http://duc.digidesign.com/showthread.php?t=236131
003r/i7-930/LE 8.0.1 cs2 on xp
Old 05-27-2010, 07:30 PM
Thanks 77pro, I found the .dll file where you said it was and moved it, thanks.
Now I have another problem on start up!
I'm getting an access violation.
.....unable to read 0x00000000 at address 0x00000000 in module ProToolsLE.exe
I can only guess all of this is because of Automap again. It works flawlessly in Cakewalk.
any ideas?
Cheers.
Old 04-27-2013, 08:30 AM
ctheys ctheys is offline
Just in case anyone has this problem... now in 2013 with PT10 on Win 7 64 bit.
For some reason that message started popping up (no idea why!!). I found the file under the Common file folder DAE/plug-ins. So I left it there and copied it in C:\programs files (x86)\avid\Pro Tools.
There are a bunch of dll files there so that's where I put it. The DAE folder in here does not have a Plug-Ins folder...
Hope this helps.
Old 04-27-2013, 09:40 PM
BoomTap BoomTap is offline
Hope this helps.
You've Turnt' Up... U rock! Thanks.
Old 07-21-2013, 01:23 PM
RaymondPQ RaymondPQ is offline
Hope this helps.
Yeah, it worked for me too. Thanks!
Old 02-25-2016, 05:54 PM
hdouble37 hdouble37 is offline
I've tried it, it didn't work. I'm using Pro Tools 10 with windows 8. Could you please help me?
Old 02-25-2016, 10:26 PM
Sanobabits's Avatar
Sanobabits Sanobabits is offline
Try a reinstall/repair installation
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? bashville Pro Tools 10 5 03-23-2013 03:04 PM
"Error, missing ILok authorization for "Pro Tools 10". johkav Pro Tools Software (Mac) 4 09-10-2012 08:13 AM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 12:28 PM
"Quicktime Priority" options missing and h264 playback stutter Sawdust 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-03-2010 12:55 PM
The "FATE" of CM LABS "MotorMix" & "MotorMate". Dum dum dum dum... leon777 Pro Tools TDM Systems (Mac) 21 10-15-2002 12:00 AM
