Old 05-13-2010, 06:50 PM
jadown jadown is offline
Default Free Mixing & Mastering Templates
Are there any free mixing & mastering templates that I can download that have different genres other than the ones that comes with Pro Tools? I make mostly R&B, Pop, and some Hip-Hip. But I would love to have some templates that has whatever eq, compressor, reverb, etc placed on your standard instruments for each genre. If anyone knows of any please let me know.
Thanks
Old 05-13-2010, 07:01 PM
joey santos joey santos is offline
Default Re: Free Mixing & Mastering Templates
If you have waves.... The eq presets by great mixing engineers are available for free on their site, waves.com
Old 05-14-2010, 12:30 AM
tamasdragon tamasdragon is offline
Imho these kind of templates and presets are nearly useless. They might work in 1 situation from a thousand, but really, you cannot go too far with them.
You have to learn how to use things, and the added bonus with this method would be that you are actually able to manipulate the sound the way you want, and not only praying for the best.
Presets are only starting points, but many times they even failed to be that.
my blog:Tamas Dragon
Old 05-14-2010, 12:40 AM
elmostephane elmostephane is offline
Never heard of such thing (I believe you're talking about PT session templates, not plugin presets). The reason why this doesn't exist I think is because everyone has got a different way of laying down their tracks, aux, fx, etc...
As far as mastering goes, I have made my own MS mastering template that I'd be happy to share you if you want. It's just a basic MS matrix decoder using the standard PT plugins so it works on any system.
Send me your email address if needed.
EDM Mixing & Mastering
EDM Mix Master www.edm-mix-master.com
Soundcloud - www.soundcloud.com/jotheo
Old 05-14-2010, 01:09 AM
GW GW is offline
Thanks
If you want to save time and grief - ask a seasoned PT user to give you 40-50 min support session and sit next to him and formulate what you want and why and simply save that as your personal template. I save my personal templates in Pro Tools all the time, but adding Logic to my system I did just that - I included the template making support in my buy of a new mixer unit that I got!
I usually mix on different 8 channel mixers, therefor I place from left to right -
  • Mastertrack with plugins inactivated
  • Hardware Reverb via SPdif
  • Software Reverb on Power Core
  • Software Delay
  • Instrumenttrack with EZ-Drums output bus Drums
  • Audiotrack - input bus Drums
  • Instrumenttrack with Bass Trilian outout bus Bass
    with the instrumenttrack plugins made Inactive for faster loadtimes
...and so on and so on. When I ride the unit with the Bank selected I always have Matering tracks on my left hand to the left and have my vocal-tracks last on the right side...
I just did this long posting to clear out that a basic strategy saved as a personal template can save a lot of time.
(Don't forget to add a setup with Memory locations and place you most used genre typical naming like Intro, Vers 1, Ref 1, Vers 2, Outtro and just drag them into position)
PT 12.4.0, iMac 27" Retina 4GHz i7, 32GB RAM, PoCo x8,
Digi002 Fact., Logic X|FCPX|Motion
Plugins: Waves Diam. V9|Artist Sign Ser.|SSL|GTR3.5, TC MD3|Harm4|VSS3|DVR2|Nonlin|Unwrap, Sonnox Infl|Dyn, Autotune
VI: Reason 8, Ivory It., Trilian|Omnisphere, VG2/RealGuitar, Kontakt6|GPO, Goliath|Gypsy|Fab Four, Candy, Structure, EZdrum, BIAB Audiophile
Hardware: TLM49|TLM103, SPL Track One, TC M-One, Artist Contr.v2|Transp|3xMix
Old 05-14-2010, 05:52 AM
Here's a bit of a guideline to get you on the track of clean sessions...:
As a general rule, every track should be routed to a bus that will group different frequency areas:
kicks
drumloops (as well as parallel comp drumloop bus)
guitars (divided into more buses if using acoustic + electric, both then router to a master guitars bus)
piano
synths
bass
reverb1
reverb2
delay (really short that acts like reverb)
delay (FX, usually triplets with low feedback)
delay (FX, quarter note with longer feedback)
master fader
Every bus should have:
HPF on it, where you put that filter depends on the instrument being processed.
EQ should be applied with "niche EQ" techniques.
transient designer (only on some buses though)
Compressor
brightening EQ
Tape saturation
Master should have:
EQ
Comp
Harmonic enhancer
Brightening EQ
tape saturation
Limiter
But then again, this is only a guideline and may not work in every situation. But at least it'll give you a good starting point...
Good Luck!
Old 05-14-2010, 06:13 AM
The Dougfather The Dougfather is offline
Izotope Ozone has some halfway decent presets that would get you going.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Old 05-14-2010, 12:02 PM
GW GW is offline
Hahaha... Reading these post you gotta admit that my first advice was the best - buy a guy a couple of bears to sit beside you and help you out doing your personalized template!
Old 05-14-2010, 03:34 PM
Definitely a great starting point, but don't think Ozone is the "be all end all" as you will find after using it for a while, you can get much better results with individual processors of each of those components...
Old 05-14-2010, 06:04 PM
Trainwreckmusic Trainwreckmusic is offline
Originally Posted by GW View Post
Hahaha... - buy a guy a couple of bears to sit beside you and help you out doing your personalized template!
Wow now we have to compete with trained bears in the studio?
I understand they work for berries and grubs...and some "Silly Old Bear" will mix for a pot of honey at "the 100 Acre Woods Studios". But I hear all his mixes sound like "Pooh" -- and the faders are always sticky when he's done. LOL!
Does Pro Tools have on board Mastering preset templates? Danny Winn Pro Tools 10 3 09-10-2012 08:34 AM
Mixing and Mastering spidey901 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-12-2007 10:40 AM
mixing templates P.O. Digidesign Hardware & Software 1 02-28-2007 09:12 AM
mixing templates P.O. Digidesign Hardware & Software 0 02-02-2007 10:49 AM
Mixing / Mastering for TV???? pepperman Tips & Tricks 5 07-23-2003 05:24 PM
