Old 04-23-2010, 09:14 AM
kankzzz kankzzz is offline
Default Digi 003 rack ,input issues :(
I just upgraded from 002 to a 003 rack , and Im kinda new with it, I was trying to record drums with it the other day and I was trying to use the 8 inputs but input 3 and 4 are not working at all, the guy i bought it from says there is a trick on the 003 that i gotta do to make them work, Im confused, have anyone experienced anything like this, is this a real issue of the 003s or maybe the unit got problems, cause I know the 002 was pretty easy,just plug select your input and go,
Old 04-23-2010, 09:15 AM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Default Re: Digi 003 rack ,input issues :(
Sounds like u may hav got tricked
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 04-23-2010, 02:44 PM
I wonder if he is referring to the "trick' of fixing the manufacturing goof. The first production run of 003Rack units had a bundle of wires tied off a bit too tight and they would pull a connector off the input board, disabling inputs 3&4. If I remember right, the solution was to clip off a wire tie and reseat the connector. This assumes that the inputs are made available in the IO setup page....
Old 05-27-2010, 07:47 PM
pitrow pitrow is offline
Did anyone have a solution for this?
I just picked up a 003, open box that I can still return so may just do that.
Same issue. Inputs 1 & 2 work fine. Inputs 5-8 also work fine with external pres. Inputs 3 & 4 show up in my I/O, but I get no signal either with a Xlr cable or using a 1/4 inch into the DI.
Sounds like a bum connection to me so may have to take this back.
Old 05-27-2010, 08:02 PM
Did you try opening the unit and reseating cables?
Old 05-28-2010, 08:04 AM
SpinningDisk's Avatar
SpinningDisk SpinningDisk is offline
Did you ask him why he was selling it?
Old 05-28-2010, 08:47 AM
@albee1952: I did not open it up. I suppose I could try that first. Less hassle than going back in assuming it's a quick fix.
@SpinningDisk: It was a floor model, but looked in good shape, covered under full warranty, and according to him, totally working. Although I now know that's not the case.
Old 04-17-2012, 11:40 PM
Dprincewillz Dprincewillz is offline
Guys please could some one help us on this issue. I am experiencing the same problem
On my unit 003 rack. line In 1,2,3,4,5 has no audio signal. I have updated the new driver for the unit but still not working.
Thanks
Old 04-18-2012, 05:30 AM
You do see the 003 Rack under interfaces when you boot up PT?
Old 04-18-2012, 12:21 PM
Thanks
Is this the rack + version or the rack with only 4 mic preamps? Have you tried the Mic/DI buttons on the front?
Midi input issues PT10.3.5 003 rack+ animalaudio macOS 2 06-25-2013 05:45 AM
Input 2 on Digi Rack 002 not working capeside 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-07-2011 02:41 PM
Mic 3-4 Input Issues 003 Rack dlipsjr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-12-2011 05:18 PM
Digi 002 Rack Input Sensitivity docofrock1968 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-17-2004 12:16 PM
I/O LINE INPUT, I/O OPTICAL INPUT DIGI 002 RACK JOAN ROSALES 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-28-2003 04:08 PM
