Old 04-03-2010, 10:31 PM
ruper ruper is offline
Default I can't hear my voice while recording vocals with MBox 2 Pro
Hi all:
I was using an old MBox and I didn't have any problem to adjust the volume in the headphones higher than that of the mix, so that I could hear my voice while I was recording a vocal.
I recently bought an MBox 2 Pro, and I have not been able to figure out how to hear my voice louder that the mix in the headphones. If I turn the volume of the headphone louder then the mix also goes louder and I can't still hear my voice.The result is that I go out of tune since I can't hear my self.
I was thinking to buy a small mixer to blend the two headphone outputs (A & B) into a single one, but sending the output of the track where I an recording the vocals to, through the Output 3-4 at Headphone B.
How do you go about this with the MBox 2 Pro without having to buy extra gear?
There must be a simpler way to do this! It was so simple in the old MBox!
Thanks in advance for your feedback
Old 04-03-2010, 11:30 PM
stonehenge stonehenge is offline
Default Re: I can't hear my voice while recording vocals with MBox 2 Pro
can't you just raise the fader of the track you are recording on?
Old 04-04-2010, 02:34 AM
huzzam huzzam is offline
What Stonehenge said: just raise the fader for the track you're recording in the mixer.
The difference between the old Mbox & the Mbox 2 Pro is that the Pro doesn't have direct monitoring (for some reason), which is what the old Mix knob controlled. Now everything you hear via the headphones goes through Pro Tools first. This means you have to mix it all in the Pro Tools mixer.
This is also why you may want to either 1) select "low latency monitoring" from the options menu and/or 2) select a low playback buffer size, perhaps 128 samples, in the playback engine window. Since things have to go through PT, there's delay before it gets back out. This can throw you off when tracking. Both of these options can help minimize that delay.
~peter in oakland
Old 04-04-2010, 06:01 AM
Thanks a lot guys. This very useful. I will give it try and may get back for more help!
Thanks again
Old 04-04-2010, 07:58 AM
And also, make sure you don't accidentally select Input Only monitoring. Raising the fader should do the trick as it has no affect on the recording level. I find pushing it to +9 is about right.
Asus x99, Intel i7 6800K, 32 gig DDR4, GeForce 750 Ti, HD/Native, HD IOx2, PT11HD, UAD Quad, preamps from Vintech, Five Fish Audio, Miktek, Focusrite, Chameleon Labs and Midas..............................
www.capricornsoundworks.com
Old 04-04-2010, 08:15 AM
audiogeekzine audiogeekzine is offline
do you use the option for separate recording and playback fader levels?
+9 while tracking will be good for the performer, but if you want to play back the take in context with the mix bringing it back to 0 each time and back up to +9 for the next take is annoying, no?
Also pushing the fader to +9 will probably show clipping on the meters so you can't rely on them.
@theaudiogeek
| www.EPICSounds.ca | www.AudioGeekZine.com | www.HomeRecordingShow.com |
Old 04-04-2010, 04:58 PM
Hi:
Thanks for your input. Where is the option for separate recording and playback faders?
Old 04-04-2010, 05:13 PM
irishharry irishharry is offline
There are no recording faders. The fader always controls the sound that is playing back to you. It wont effect the recorded level whatsoever. Your recording level is only set by the input knob on your Mbox
Last edited by irishharry; 04-04-2010 at 05:14 PM. Reason: Horrendous spelling and using 'you're' instead of 'your'. Oh the shame!
Old 04-04-2010, 06:34 PM
irishharry spelled it out nice and clear. As long as the meters are in Pre-fader(they are by default) then the meter will show accurate recording level, regardless of the fader setting. I simply leave the fader at +9 until the track is fully recorded and drag it back to -0 when I am ready to start editing. mixing and adding plugins. In 5 years, this has never been an issue with any client.
Can't hear own voice while recording it speilegg Pro Tools Software (Mac) 4 08-17-2011 07:09 AM
Cannot hear voice recording during playback tearywh Pro Tools M-Powered (Win) 1 03-06-2011 01:55 PM
Why do I hear an echo when I'm recording vocals danielontiveros Pro Tools M-Powered (Win) 5 02-04-2010 08:21 PM
Can't hear vocals during recording mikecamp1978 Pro Tools M-Powered (Mac) 5 04-25-2009 01:45 PM
hear vocals during playback w/o actually recording them? Esteban 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 03-08-2002 12:59 AM
