Old 03-27-2010, 12:00 AM
JNS JNS is offline
Default Control 24 automation LEDs reversed
Hi. I recently went from PT 5.1.1 to 8.0.3cs1 and was surprised and confused to see that the operation of the red LEDs for "Write", "Touch", and "Latch" modes is reversed. In other words, for example, when arming a channel/channels for "Touch" automation the LED should flash and then when the fader is touched and automation is actually being written the LED should be solid red. In my case it's just the opposite. I've also tried this in PT 7.4.2cs4 and gotten the same results. I also checked with another Control 24 user and their unit performs the same as mine. This is counter-intuitive and driving me crazy and I was wondering when/why it got switched from the normal mode as described in the Control 24 manual. I've checked twice with Digi and gotten nowhere on this issue. My Control 24 firmware is version 1.08. Fortunately, the automation is being written and the on-screen information is correct.
Thanks,
Jeff
HD3 Accel with 2-192s(expanded) and Rosetta 800, PT 8.0.3cs2/10.5.8 on 8-core 2.8 GHz. MacPro with UAD-2 Solo/Duo and Magma Expressbox4 chassis, Sync I/O, Midi I/O, Control 24;
PTLE 8.0cs3 on Dual-core 2.3GHz. G5(PCIe), 003R
Control 24: Preamps not working and Peak leds are lit at all times andreconde ICON & C|24 2 11-07-2014 03:37 PM
003 powers up with all LEDs lit and no control surface function tsvisser 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-26-2009 03:48 AM
Help with Control 24 Issue of Flashing LEDS and Clicking Sound ekatsuleres ICON & C|24 5 08-08-2009 02:13 PM
D-Command leds blinking while writing automation?? ARTHANOR Productions ICON & C|24 1 11-22-2006 12:55 AM
Help! Pro Control/Fader Pac reversed Ted C Pro Tools TDM Systems (Mac) 2 09-06-2002 11:55 PM
