Old 03-15-2010, 04:06 PM
malicegreene malicegreene is offline
Default Auto Tune in Real Time
looking for help on how to get auto tune in real time while recording on Pro Tools...
i have an aux track with the input set to Mic 1 ... and the output set to Bus 1
I have the auto tune plug in on that aux track ...
I have a audio track with the input set to Bus 1 and the output set to Main Stereo Out 1-2 ...
when i record i do not hear the auto tune effect live ...
is there anyone that can assist on what step i am missing ...
thanks
Old 03-15-2010, 04:47 PM
lego lego is offline
Default Re: Auto Tune in Real Time
Not enough info to guess, but if you are on LE with some specific hardware you might have Low Latency Monitoring switched ON in Options.
"The Mackey Big Knob is, you press little button and they can hear through the headphones, you can say whatever you wanted to them without you having to yell." by Tad Donley
Old 03-15-2010, 07:51 PM
nst7 nst7 is offline
I second what Lego said. Can you try using any other effects (like reverb) that way and see if you can hear them?
Old 03-16-2010, 07:55 AM
1ace1 1ace1 is offline
An aux track has no record arm function so how is signal even getting into protools from the mic??
Try this....
Create two mono audio tracks and one mono aux track.
Set the input for audio track 1 to be mic/line 1 and the output to bus 1
Place your auto tune on the aux track and set its input as bus 1 and output as analogue 1-2 (for monitoring).
On your second audio track set the input as bus 2 and mute the output for now
Now go back to the aux track and create a send to bus 2, turn up this send.
Arm both audio tracks and record.
This will give you the dry vocal on the first audio track and the autotuned vocal on the second audio track.
There are other configirations to achieve the same result (by having sends and i/o's in different places etc...)
However.....
Going to tape with autotune will yeild unsatisfactory results imho.
What are you trying achieve?
Is there a need to do this or just a want?
A:)
I Love Audio!!!
Old 03-16-2010, 02:10 PM
Straight from the input! Simply set AUX track's input to Interface and voila!
Old 03-16-2010, 04:19 PM
chrisdee's Avatar
chrisdee chrisdee is offline
Just put it on the audio track you record on, and remember to disable low latency monitoring.
Old 03-18-2010, 03:40 AM
Ah ha!!
Never really had a need to use aux tracks in that way. Always learning every day.
A:)
I Love Audio!!!
PT 8 - RTAS Plugin Real Time (Auto Tune Evo) new dj 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-10-2009 03:51 PM
Time delay / Auto Tune 5 tim carter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-05-2007 03:17 PM
Auto Tune - Real Time or Audio Suite + Questions? epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-03-2006 08:47 PM
Auto Tune & Pitch & Time on 7.1 PCI e & Quad TommyT Pro Tools TDM Systems (Mac) 0 12-23-2005 08:43 AM
Auto-Tune.. Real-Time or Render? JonnyGinese 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 08-10-2005 07:10 AM
