Avid @ NAMM 2018
Old 02-23-2010, 05:56 AM
crimsonnoise crimsonnoise is offline
Default "Elastic Audio plug-ins are not installed"
In PT 8.01cs1 I am getting this message under the Elastic Menu options. Is there really an EA plugin that needs installing? I can't find it anywhere. Perhaps something went wrong with the install from v7.4 to v8.01cs1?
PT 8.0.1cs1, HD Accel 2, Mac Pro 8 core 2.8GHz, Mac OS 10.5.8, Digi 192, ADAT Bridge 24, Logic 9.1 using DAE and Core Audio with RME Fireface 400
Old 02-23-2010, 02:13 PM
DigiTechSupt's Avatar
Default Re: "Elastic Audio plug-ins are not installed"
You should have an Elastic Audio.dpm plug-in in your plug-ins folder.
If not, run the Pro Tools installer again and in the Custom install menu, check only Digirack plug-ins, which should reinstall the stock plug-ins, including EA.
Avid Audio Tech Support
Support FAQ
WTH is an "embedded fade"? (PT8 Elastic Audio error) jsbeeth 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-17-2015 05:15 AM
PT 11 - "Elastic Audio plug-ins are not installed" fenyxkell Pro Tools 11 1 07-01-2013 12:15 PM
Import session data... please break out "plug in settings" and "plug in automation" yeloocevad Pro Tools TDM Systems (Mac) 19 10-05-2011 01:04 PM
Elastic Audio "Not Installed" ? JamLewis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-21-2009 03:12 PM
Elastic Audio putting "bump" in EGtr transients holden Pro Tools TDM Systems (Mac) 0 08-13-2008 02:19 PM
