  #21
Old 02-28-2010, 06:53 PM
Aderivas Aderivas is offline
Default Re: Melodyne Plugin ERROR (MPView Not Found) Win XP Protools LE 8.0.3
Yes, it's actually the Lexicon Plugin causing all the trouble.
I just got rid of the dpm/rsr Lexicon files, as well as the 'resources' folder that it installs in the Plug-ins folder. And now Melodyne works as expected.
I didn't have to reinstall Melodyne, by the way.
Thanks.
Core 2 Quad 2.4 CPU
Intel D975XBX2 Motherboard
8 GB RAM
ProjectMix / M-Powered 8.03 / W7 64
  #22
Old 02-28-2010, 09:49 PM
P4Vi7 P4Vi7 is offline
This is great news - I was having this problem and this is indeed a fix.....but... What if I want to use Lex And Melo in same session ? I guess we have to wait for a fix ( prob on Lex's side ).
btw I was searching for all this 'MPview' stuff to but could find no 'real' info about it.
I might just go to the Lex forums and let them know :)
  #23
Old 02-28-2010, 11:58 PM
music project music project is offline
i am happy to hear this helped you.
i sent an Email to the lexicon guys and am using the vst version thru fxpansion's vst to rtas wrraper.
so there is an option of using melodyne and lexicon on the same session.
2009 8 core mac pro "nehalem" with 6GB ram, 002R, command 8, pt 10.3.5
  #24
Old 03-01-2010, 03:24 PM
jimst57 jimst57 is offline
Thanks.
Yes that worked here too.
Thanks to whoever discovered this.
  #25
Old 03-02-2010, 09:11 AM
CORFA CORFA is offline
Thank you guys!!!!
I really lost all hopes almost already..
Discussing is a great thing!!!
Lexicon is great, but bug...:)
  #26
Old 03-02-2010, 09:17 AM
stickboymusic stickboymusic is offline
strangely the fix didnt work for me - i completely uninstalled lexicon reverbs but still the same error - did you guys have to system restore back to before installing lexicon?
Odd
  #27
Old 03-02-2010, 09:23 AM
I didn't make System Restore. Just uninstalled PCM Lexicon
But I also uninstalled Internet Explorer 8. It caused some errors for protools
Try it if you have one..
  #28
Old 03-02-2010, 09:26 AM
hmmmm no i dont have internet explorer 8 - very strange
i will try again tonight i guess - i just kinda gave up on it after many attempts
  #29
Old 03-04-2010, 04:05 PM
Eway Eway is offline
Hi ,
This is not a Protools version problem.
This is a Visual C++ Runtime library problem. Either since you run Melodyne plugin you have installed an another prog or plugin none compatible who runs with a newer version of Visual C++ Runtime library either a newer version of Visual C++ Runtime library was installed before you tried melodyne. In both case it's not compatible. you can eventually try to uninstall Visual C++ Runtime library to see what happens and reinstall this version: Visual C++2005 Runtime librar.
edit: And Yes Lexicon reverb cause this trouble
  #30
Old 05-03-2010, 10:30 AM
685 685 is offline
You all are great. We just tried the "remove Lexicon rtas files" on a friend's computer and it worked. Melodyne opened. Added the lexicon files again and the error popped up again.
TDM Plugin not Found, -7 Error Message Reatsch Windows 15 05-28-2013 11:26 AM
Melodyne editor vs Melodyne plugin smpkeys Pro Tools 9 3 03-17-2011 01:33 AM
Melodyne plugin??? basslik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 08-05-2010 07:09 AM
Melodyne Plugin brandymania1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-05-2007 06:31 PM
Melodyne Plugin Siegfried Meier Pro Tools TDM Systems (Mac) 4 02-17-2007 05:52 PM
