Old 02-11-2010, 05:59 PM
steveooo steveooo is offline
Default Midi is played on time but midi notes are early on play back.
Im using PT 7.3 on a g5 (power PC).
When im recording the notes sound in time. When I play it back its off. Insert quantize is not on.
I recorded audio of me recording the midi and when you compare the 2 you can see im playing it in time by looking at the audio but the midi is early.
Here is the image, The first track is the snare (this is what I was recording). at the bottom you can see the kick(already recorded and quantized). The middle track is the combined audio.
http://www.ifindcds.com/track.png
Old 02-11-2010, 06:32 PM
BradLyons BradLyons is offline
Default Re: Midi is played on time but midi notes are early on play back.
Is this for ALL of your MIDI tracks or just that one? Can you look at the MIDI notes as you're recording them to see?
Thank you, Brad Lyons
GC PRO- Pro Accounts Manager
(404)844-9758
blyons@gcpro.com
www.theaudioprofessional.com
Old 02-11-2010, 06:54 PM
DigiTechSupt's Avatar
Do you have any plug-ins on the Master Fader? Do you have any value in the Global MIDI offset preference?
Avid Audio Tech Support
Support FAQ
Old 02-12-2010, 12:07 PM
Brad, It seems to happen to all midi tracks as im recording them.
Digi, I dont have any plug ins on the master (or any fader) and the Global MIDI offset is 0.
Old 02-27-2010, 09:34 PM
SoloHits SoloHits is offline
Same thing happenning to me.
Any solution for this?
Very very annoying.
Actually... is funny!
2010 and this stuff happenning?
"Do you have any plug-ins on the Master Fader? Do you have any value in the Global MIDI offset preference? Do you have any plug-ins on the Master Fader? Do you have any value in the Global MIDI offset preference? "
Should I?
Brand new IMac and installation.
Shoul I enter a magic number there?
Running Digi 003 Rack in a new IMac 27"....Wasup????
Old 02-28-2010, 02:53 AM
midi sordino midi sordino is offline
Your hardware buffer setting may be too high when recording midi. This means that you need to play notes early to sound on time with the metronome track. Try recording midi with hardware buffer settings of 256 or lower.
Old 10-15-2019, 05:47 AM
XJENSEN XJENSEN is offline
Seems still a problem in 2019.6...
Old 06-19-2020, 06:41 PM
jimax jimax is offline
Yep, and still the case in june 2020
Old 06-20-2020, 03:23 PM
64 is the largest number I have ever been able to live with while tracking Also, open your IO Setup window and look at the INPUT and OUTPUT tabs for a checkbox to "Compensate after a Record Pass"(or something similar to that). If you find that option try it checked and unchecked to see if either option works better.(I remember seeing this option when I had my 003 in my setup, but with my current Presonus Studio 1810C, I don't see it. Not sure if its gone because of PT updates or because I now run a 3rd party interface).
Old 06-20-2020, 05:52 PM
JFreak's Avatar
JFreak JFreak is offline
Depends on your interface also, but for me 256@48k is acceptable and 512@48k is unbearable. Many times when I checked fully built TDM mixer latency nubmers they also float somewhere around 350 sample so all that zero latency is nonsense.
Janne
Manually played MIDI Notes arrive earlier than played. SmokinBaldMonkey macOS 7 10-16-2019 06:47 AM
Showing MIDI Notes Being Played While in MIDI Editor Window? ianbee Pro Tools 10 12 10-12-2016 06:39 AM
Can you see MIDI notes that are being played in PT11? ianbee Windows 6 09-15-2013 08:55 PM
Midi Notes will not play back greenglassdrum macOS 5 01-24-2012 12:08 PM
Notes played in Midi Editor Nullifer Pro Tools M-Powered (Win) 2 04-01-2011 02:04 PM
