Old 01-13-2010, 06:19 AM
M2E M2E is offline
Default Delay compensation engine!!!!
I'm trying to get my head around this. I have my Pro Tools set for Long (4095 PER CHANNEL) but, when it hit's over 2000 it shows in the red.
Also, when it hits in the 1000's it shows in the orange.
Can some one from Digi please tell me if we really do have 4095 per channel?
This gets so annoying when mixing ITB and you have to stop ur work flow to try to figure out a work around which takes you off ur main objective.
Anybody else with the same issue?
Thanx
Marc
Mac Pro 2.66ghz/PTHD3-8.1.1/OS 10.6.8/192 & 96i/12 Gigs Of RAM
Old 01-13-2010, 09:05 AM
Sean Russell Sean Russell is offline
Default Re: Delay compensation engine!!!!
Yes, you do have 4095 - orange means it's the most compensated channel in the session. Red means you've exceeded that comp. Is this track an Aux? Are there TDM plugs and RTAS plugs together on the track - maybe RTAS before the TDM? Swap them.
... but does it help the chorus?
Old 01-13-2010, 09:25 AM
KingFish KingFish is offline
You mixer will incur greater delays, at higher buffer sizes as well.
if you're hovering around the Delay compensation limit at 1024, and you lower your playback Buffer to 512, all of the delays in the Mixer, will be 1/2 (I don't know if it's exactly 50% off hand, not in front of my HD system.... but it's less)
I try to run, mostly at 128 these days, so I get the least delay out of my Mixer / Plugin's and stay below delay compensation Range - occasionally I'll hit the limit, and back the playback buffer off to 64, and it'll lower the delays, within range, but not too often.
David
- Trident TSM 52 Input Console
- HDX / OMNI / HD i/o's
- MacPro 8 Core 2.4 Westmere 28Gb RAM
- PT HD 10.3.3 + H.E.A.T. OS X 10.8.2
- SSL Nucleus Controller
- Dynaudio Acoustics BM6A's / Genelec 8040a / NS10's w/ Sub
- 1176's, LA2A's, ADL CL1500, Neve 1073's, 16 x Wunder Audio Pre's, Ward Beck's, API's, Misc Vintage outboard.
- 2x - HD3 Accel PCIe - 192 i/o's - 96 i/o's
Old 01-13-2010, 10:33 AM
crizdee's Avatar
crizdee crizdee is offline
Yes and if its an aux! any tracks feeding the aux are added the delay reading.
snare track creating 2000 fed to an an with 2000 = 4000
Chris
Producer, Engineer,
UKmastering E-Mixing & Mastering facility
www.ukmastering.com
PT10.3.7 Lion HD6 accel Magma PE6R4 Control 24 Harpertown 8-core UAD-2 Quad / SSL Duende Native. Manley Vari-Mu, Manley Massive Passive, Solid State Logic VHD, Anthony De Mario ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Delay Compensation in "Playback Engine"? RokVox Pro Tools 11 Discussion 8 09-11-2013 11:38 AM
Delay compensation engine crash urfavoriteblbsie Pro Tools 9 Discussion 4 02-25-2012 07:30 PM
Delay compensation engine mafiacondon Pro Tools TDM Systems (Mac) 2 10-11-2010 04:45 AM
Delay Compensation Engine Fails to Warn Nathan W. Pro Tools TDM Systems (Mac) 2 09-17-2010 04:13 PM
8.0.3 - More samples in Delay Compensation engine? cburgett Pro Tools TDM Systems (Win) 4 12-19-2009 06:27 PM
