Old 01-11-2010, 04:27 AM
MIKEROPHONICS's Avatar
MIKEROPHONICS MIKEROPHONICS is offline
Default 8.03 Behavior to VPN attached drives is different...
Dear All
re 8.03
When I connect to my client via vpn and mount his macpro PT drives via afp and copy stuff via drag and drop using the finder into my regions bin (singular bin note - ahem digi ....) - I am getting a dialogue about the remote drives being transfer only- which never happened before (the files previously just copied into my session). Once I have told the "prompt box" where to copy to,, I then get an access violation (ouch). The files do copy to the session folder and re opening the session means that all is well.
This is a tad annoying to say the least. Is it a timeout issue?
OSX 10.5.8
HD3, 192, sync io, procontrol
Macpro 3GHz fourcore xenon 8G ram
mojo
cheers
cheers
Mike Aiton BSc (hons)
Dubbing Mixer/Sound Designer
BAFTA member
IPS member
former Post Production Expert at www.pro-tools-expert.com
www.mikerophonics.com
Old 01-11-2010, 07:01 AM
blank blank is offline
Default Re: 8.03 Behavior to VPN attached drives is different...
What are you using for vpn client ? Does your vpn use hardware like cisco or sonicwall or its a transfer only one ?
I had issues like this using apple filesharing protocol over software vpn on a mac ( not for protools ).
If I remember well, using samba share instread of afp could help solve the problem. This bug is more on the apple side imho.
Network Attached Storage (NAS) drives John_Toolbox Storage Subsystems 6 04-19-2015 12:29 PM
PT9 without hardware attached? SNAPPER Windows 8 02-11-2011 12:52 PM
using protools without 002 attached mcclark 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 07-08-2008 12:18 PM
How to Start LE to mix without attached to 002? RobertJackson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-06-2004 05:21 PM
Mixing without Mbox attached? J. Guerrero 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 04-28-2003 06:23 AM
