Avid Pro Audio CommunityHow to Join & Post • Community Terms of Use • Help Us Help YouKnowledge Base Search • Community Search • Additional Resources |
I'm running XP SP3 32-bit, with BFD2 v2.1.0.47. I recently upgraded to PTMP 8.0.3, and found an interesting bug this week. This was not an issue on previous versions.
When my BFD2 window overlaps the PT window, I can drag grooves from the groove editor directly into the PT region editor just fine. If the BFD2 window does not overlap the PT window, then dragging the groove from BFD2 into the PT editor causes PT to hang, and gives the following error message: Access violation occurred, unable to read location: 0x00000000 at address: 0x00993EE3 in module: DFW.dll I also get the same issue if for some reason I drag the BFD2 groove in any place not over the PT region edit window; i.e. over PT that is not part of the Region Editor, such as over the Mix window, over the desktop (as in if the BFD2 window doesn't overlap the PT window). So far, I've found the issue to be 100% reproducible. The workaround is to make sure that BFD2 always overlaps the PT editor when moving grooves into PT. However, as this is an important part of my workflow, I'd like to see it corrected. I'm not sure whose issue this is, so I've cross-posted it over at FXPansion's web site. My suspicion is that since DFW.dll belongs to ProTools, that it would be Didigdesign's issue. Thanks. SiSoftware Sandra System Host Name : PROTOOLS User : ProTools-User Workgroup : HOME Processor Model : 2x Intel(R) Xeon(R) CPU X5350 @ 2.66GHz Speed : 2.66GHz Cores per Processor : 4 Unit(s) Threads per Core : 1 Unit(s) Type : Quad-Core Internal Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 2x 4MB, ECC, Synchronous, ATC, 16-way, 64 byte line size, 2 threads sharing System System : Dell Inc. Precision WorkStation 690 Mainboard : Dell Inc. 0MY171 Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : 2 Processor(s) Multi-Processor Advanced PIC (APIC) : Yes System BIOS : Dell Inc. A04 Total Memory : 2.5GB DDR2 FB-DIMM Chipset Model : Intel 5000X Chipset Memory Controller Hub Front Side Bus Speed : 4x 266MHz (1.06GHz) Total Memory : 4GB DDR2 FB-DIMM Memory Bus Speed : 2x 266MHz (532MHz) Memory Module(s) Memory Module : Quimoda 72T128020HFN37A 1GB ECC DDR2 FB-DIMM PC2-4300F DDR2-534 (4-4-4-12 2-16-4-2) Memory Module : Quimoda 72T128020HFN37A 1GB ECC DDR2 FB-DIMM PC2-4300F DDR2-534 (4-4-4-12 2-16-4-2) Video System Adapter : NVIDIA Quadro NVS 285 (128MB DDR3, 275MHz/2x598MHz, PCIe 1.00 x16, PS3.0, VS3.0, 2 Heads) Adapter : NVIDIA Quadro NVS 285 (128MB DDR3, 275MHz/2x598MHz, PCIe 1.00 x16, PS3.0, VS3.0) Storage Devices WDC WD5000AAKS-00YGA 500GB (SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 466GB ST31500341AS 2TB (SATA300, 3.5", NCQ) : 1TB (D:) ST31000333AS 1TB (SATA300, 3.5", NCQ) : 932GB (E:) ATA MAXTOR STM350063 500GB (SCSI, SCSI-5, 3.5", 20000rpm, NCQ) : 466GB (C:) (J:) TEAC USB HS-CF Card (USB) : N/A (G:) TEAC USB HS-xD/SM (USB) : N/A (H:) TEAC USB HS-MS Card (USB) : N/A (I:) TEAC USB HS-SD Card (USB) : N/A (K:) Seagate FreeAgent 2TB (USB) : 1TB (O:) TSSTcorp CDDVDW SH-S202N (ATA66, DVD+-RW, CD-RW, 2MB Cache) : N/A (F:) PHILIPS DVD+-RW DVD8801 (ATA33, DVD+-RW, CD-RW, 2MB Cache) : N/A (L:) Logical Storage Devices System (C:) : 234GB (NTFS) @ ATA MAXTOR STM350063 500GB (SCSI, SCSI-5, 3.5", 20000rpm, NCQ) System (J:) : 231GB (NTFS) @ ATA MAXTOR STM350063 500GB (SCSI, SCSI-5, 3.5", 20000rpm, NCQ) Hard Disk (N:) : N/A Hard Disk (M:) : N/A MainStorage (D:) : 1TB (NTFS) @ ST31500341AS 2TB (SATA300, 3.5", NCQ) Samples (E:) : 932GB (NTFS) @ ST31000333AS 1TB (SATA300, 3.5", NCQ) CD-ROM/DVD (F:) : N/A @ TSSTcorp CDDVDW SH-S202N (ATA66, DVD+-RW, CD-RW, 2MB Cache) CD-ROM/DVD (L:) : N/A @ PHILIPS DVD+-RW DVD8801 (ATA33, DVD+-RW, CD-RW, 2MB Cache) Removable Drive (G:) : N/A @ TEAC USB HS-CF Card (USB) Removable Drive (H:) : N/A @ TEAC USB HS-xD/SM (USB) Removable Drive (I:) : N/A @ TEAC USB HS-MS Card (USB) Removable Drive (K:) : N/A @ TEAC USB HS-SD Card (USB) Backup (O:) : 1TB (NTFS) @ Seagate FreeAgent 2TB (USB) Peripherals LPC Hub Controller 1 : Dell 631xESB/6321ESB/3100 LPC Interface Controller LPC Legacy Controller 1 : SMSC LPC v1 Disk Controller : Dell 631xESB/6321ESB/3100 Ultra ATA Storage Controller Disk Controller : Dell Enterprise Southbridge SATA cc=AHCI Disk Controller : Dell SAS 5/iR Integrated Emb USB Controller 1 : Dell 631xESB/6321ESB/3100 Chipset USB Universal Host Controller #1 USB Controller 2 : Dell 631xESB/6321ESB/3100 Chipset USB Universal Host Controller #2 USB Controller 3 : Dell 631xESB/6321ESB/3100 Chipset USB Universal Host Controller #3 USB Controller 4 : Dell 631xESB/6321ESB/3100 Chipset USB Universal Host Controller #4 USB Controller 5 : Dell 631xESB/6321ESB/3100 Chipset USB2 Enhanced Host Controller FireWire/1394 Controller 1 : Avlab Technology XIO2200(A) IEEE-1394a-2000 Controller (PHY/Link) FireWire/1394 Controller 2 : ADS Technologies TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller System SMBus Controller 1 : Intel 5X00/7X00 XMB Ch 21-0 SMBus System SMBus Controller 2 : Intel 5X00/7X00 XMB Ch 21-1 SMBus System SMBus Controller 3 : Intel 5X00/7X00 XMB Ch 22-0 SMBus System SMBus Controller 4 : Intel 5X00/7X00 XMB Ch 22-1 SMBus System SMBus Controller 5 : Intel 801xx/63xx SMBus Printers and Faxes Printer : HP DeskJet 1220C (1200x1200, USB, Colour) Network Services Network Adapter : Broadcom NetXtreme 57xx Gigabit Controller - Packet Scheduler Miniport (Ethernet, 100Mbps) Power Management Mains (AC) Line Status : On-Line Operating System(s) Windows System : Microsoft Windows XP Professional 5.01.2600 (Service Pack 3) Platform Compliance : x86 |
I would like to help figure out what is going on with your system/sessions. In Pro Tools 8.0.3, we added better and more robust logging to help track down problems like the one you are seeing. When Pro Tools crashes, some information about the crash is written out to a log file. The log files are kept in the "LogFiles" folder that is next to the Pro Tools application. Here's what you need to do... 1) Reproduce the crash you are seeing. 2) Look in the LogFiles folder and find the latest log file. The file name ends with .dlog 3) Email this "dlog" file to vi -at- digidesign -dot- com. Please include your DUC user name and the hyper-link to this DUC thread (http://duc.digidesign.com/showthread.php?t=262158) so we can track which post this came from. Please put my name in the subject line of the email. Thanks! |
Hey, Bob. Thanks for getting back to me. I'll recreate and send you the log right away.
Any word on this yet? It looks like someone is having the same issue, but with Superior drummer. http://duc.digidesign.com/showthread.php?t=264290
Also, I've confirmed that the same issues exists when using XP SP3 or W7-64. |
Having same problem with EZ-Drummer/Player... and 8.0.3 going back to 8.0.1
Looks like it's fixed in 8.0.3cs2 for BFD2. Thanks!
BFD2-Initial Groove start is noisy. | Broadsneakers | Pro Tools M-Powered (Win) | 1 | 05-29-2012 09:31 AM |
Using Pro Tools Midi Editor for BFD2 drum mapping | Qrackaduck | Virtual Instruments | 4 | 10-15-2009 08:53 AM |
Groove Agent (SE) in PTMP | GovrCheeze | Pro Tools M-Powered (Win) | 0 | 02-21-2007 11:22 AM |
Dragging from region bin | FDurrett | Pro Tools TDM Systems (Mac) | 4 | 08-22-2004 01:22 PM |
Dragging sounds on the SCell editor | The golfer | Digidesign Hardware & Software | 1 | 10-21-2002 09:10 AM |
