Go Back   Avid Pro Audio Community > Other Products > The Drum Room
Old 12-26-2009, 09:27 AM
Blackers Blackers is offline
Smile Drum samples for Sound Replacer
Hi friends!
Where can i find drums samples to use in Sound Replacer?
It would be necessary archives in 24 48 Kz.
Any help will appreciated.
Thanx!
Old 12-26-2009, 08:02 PM
Default Re: Drum samples for Sound Replacer
I make my own. Open ezdrummer or SD2 on an instrument track, pick a good kit and bus to an audio track. Record the drums you like(1 hit each, or more if you like to have different velocities). Use Tab to Transient to trim the leading edge, trim and fade the end and export to a handy folder. I have folders with at least a dozen samples for each shell(Bass, Snare, several toms, sidestick and plenty of cymbals, all sorted into separate folders).
Old 12-27-2009, 04:06 AM
Thanx for the tip mate.
Old 12-27-2009, 06:59 AM
sunburst79 sunburst79 is offline
The Sound Replacer Drum libraries used to all be available for download on the Sound Replacer page.....
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 12-27-2009, 03:41 PM
Oh nice,gonna check it out.
Thanx Sunburst.
Old 12-31-2009, 07:55 AM
markus44uk markus44uk is offline
Can't seem to find a Sound Replacer page that has sample downloads. Can someone point me to where it is?
Thanks
Old 01-02-2010, 11:22 AM
Exclamation Re: Drum samples for Sound Replacer
I'm also searching for this page.Any result i will let you know.
Old 02-06-2018, 08:40 AM
federico federico is offline
Hi, do you mean you don't use the soundreplacer? Or do you still use it to trigger the sound you copied from EZD2?
Thanks.
Old 02-07-2018, 03:40 PM
Thanks.
When I did use Sound Replacer, this was my method for creating my own samples. You can use any wave file, so I was describing how you can create your own. The same method will work with any virtual instrument, or you could also record your own drum sounds(with or without processing) for use in sound Replacer. Having said that, SR is quite old and pretty lame when compared to the newer drum replacement options, such as:
Slate Trigger
Drumagog
Superior Drummer 3(watch some videos on this plugin's "Tracker" feature as its a game changer)
Old 02-12-2018, 05:06 PM
WernerF WernerF is offline
Totally agree with albee1952 that Soundreplacer is pretty outdated these days. Trigger and other tools are WAY more realistic sounding. One of the reasons is that Trigger, and any modern replacement plugin, trigger multiple layers of samples and velocities. The triggering one merely a single sample will give you the machine gun effect on fills for one example. There are demo's of any of these more modern plugins. Probably is worth it to at least check them out.
Making Drum Samples from CD for Sound Replacer/Drumagog? millzboy Pro Tools M-Powered (Mac) 1 06-10-2010 03:54 PM
Is there a drum replacer/sound replacer??? sethbrand General Discussion 2 03-08-2006 08:40 AM
my sound replacer makes the samples sound higher joeldavidlauver Pro Tools TDM Systems (Mac) 2 05-24-2005 07:59 AM
What Drum Samples for 'Sound Replacer' Plug-in? mach-1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-07-2005 08:06 AM
Sound Replacer Drum Samples XCLAIM Tips & Tricks 27 03-02-2001 12:26 AM
