Old 12-11-2009, 09:52 PM
kpp9c kpp9c is offline
Question clean uninstalling Standalone Digidesign CoreAudio Driver
I installed the Standalone Digidesign CoreAudio Driver 7.4.2 so that i could use my old m-box with Peak and now i want to uninstall the whole thing completely. The uninstall directions on the site simply say to remove Library/Audio/Plug-ins/HAL/DigidesignCoreAudio.plugin
But the installer installed much more than the DigidesignCoreAudio.plugin as i see all kinds of kext files in my log now as well.
How do i do a complete and clean UNINSTALL of the whole driver.
The installer doesn't seem to have an uninstall option and there doesn't seem to be a log or receipt. I want this off my system disk completely.
cheers,
kevin
(10.5 mac intel)
Old 12-15-2009, 06:11 AM
Default Re: clean uninstalling Standalone Digidesign CoreAudio Driver
anyone? Surely someone must of installed these drivers for a gig and wanted to clear them out? Or installed the standalone drivers only to find they needed the regular drivers to use protools... no one?
Is there no uninstaller for these?
Old 01-05-2010, 07:17 AM
No one?
Old 01-05-2010, 08:54 AM
I think i got it all. Any software devs who patch your kernel with .kext files and dump this much crap in your system should provide an uninstaller. You all are horrible. Wow.
I cleaned all digi diarrhea from
Mac HD/Library/Application Support/
Digidesign folder
Mac HD/Library/Audio/MIDI Drivers/
DigidesignFireWireMIDI.plugin
DigidesignMbox2MIDI.plugin
DigidesignMIDIIODriver.plugin
DigiDioMidiDriver.plugin
Mac HD/Library/Frameworks/
DAE.framework
DHS.framework
DigidesignFWDriver.framework
DigidesignUSBDriver.framework
DigiMachOServices.framework
DigiPlatformSupport.framework
DigiPlugInHelper.framework
DigiStreamManager.framework
DirectIO.framework
DSI.framework
DSPManager.framework
DUI.framework
and
all that i found in:
/Library/StartupItems
then cleaned out:
/Library/LaunchDaemons
/Library/LaunchAgents
~/Library/LaunchAgents
to cure the:
com.digidesign.fwfamily.helper (10466) posix_spawnp/"/Library/Application Support/ Digidesign/fireWire/DigidesignFireWireHelper", ...): No such file or directory"
(look in console if you don't get this one your system will just keep trying and trying and trying to load that sucka)
all 4 or 5 kext files (evil evil evil) (click getinfo to be sure you are only deleting digicrap and not apple stuff)
whew... I am not even sure I got it all. Holy cow.
Old 01-06-2010, 10:54 AM
donbenjy donbenjy is offline
Hey, so just to be clear, do you still have PTLE stable and running? It seems like a lot of stuff for just the coreaudio drivers!
I stumbled upon this because of the digidiomididriver.plugin which craps up logic pro on SL. But it also seems like it might cure the kernel panic issue that has plagued us since 10.4.x(8 or 9 IIRC) which Digi acknowledge but don't fix. I can live with not using the mbox for other apps if it gives me a completely stable platform to use PT as well as Logic/Live! Who cares if I have to use my MBP headphone out for my HD650s? I don't use monitors outside of the studio HD system anyway!
Standalone CoreAudio Driver for Tiger Avid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 78 01-11-2007 10:26 AM
Standalone Coreaudio Driver With PT 7.1.1cs Intel thesneakyjesus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-18-2006 01:54 AM
Standalone CoreAudio Driver for Tiger Avid Pro Tools TDM Systems (Mac) 0 09-02-2005 06:21 PM
Standalone CoreAudio Driver for Tiger Avid General Announcements 0 09-02-2005 06:12 PM
