Old 11-06-2009, 05:24 AM
Delta Music Belgium's Avatar
Delta Music Belgium Delta Music Belgium is offline
Default Will Waves 7 work on a PPC G5 Dual 2 GHz with OS 10.4.x?
In the Tech Specs of Waves 7 is stated: Mac PPC - G5 Dual 2 GHz - 10.5.x (as you can read here).
But in this thread by 'ilovemyssl' I read:
Originally Posted by ilovemyssl View Post
I just updated my G5 PPC machine to Waves 7.0 Gold Bundle... everything seems to be ok except my L1+ won't open... it gives me a "DAE Error 7027" in protools
I am running PT 7.3.1cs8. According to Waves website, this configuration is compatible with Waves 7.0
PT 7.3.1cs8 needs 10.4.x...
Waves 7 needs 10.5.x...
So does Waves 7 really works on a PPC with OS 10.4.x?
I would like to upgrade my Mercury TDM bundle & SSL bundle to version 7, but I do not know if it will work with 10.4.x for sure.
@ 'ilovemyssl': where on the Waves site did you read PT 7.3.1cs 8 is compatible with Waves 7?
Btw, I made this a seperate thread because it could be interesting to know for other Waves users...
Thanks!
Marc Schellekens
Delta Music Belgium - Pro Tools|HD Studio
http://www.deltamusic.be
Mac Pro 3.33 GHz 6-core Intel Xeon "Westmere" - 32 GB RAM - OS X 10.9.5 Mavericks - Magma PE6R4-I - PT HD 6 Accel PCI - PT HD 10.3.10 - 192 I/O - 192D I/O (x2) - SYNC I/O - ProControl 48 faders - Avid Mojo - Apogee Big Ben + Rosetta 200
On the same Mac Pro also running macOS 10.12.6 Sierra + PT Native 12.8.1 with a Focusrite Saffire PRO 24 DSP
Old 11-07-2009, 02:16 AM
ilovemyssl ilovemyssl is offline
Default Re: Will Waves 7 work on a PPC G5 Dual 2 GHz with OS 10.4.x?
Hey man...
Here's the link to the Waves 7.0 "Tech specs" page for Mac PPC which lists ProTools HD compatible hosts as 7.3.1-8.01.
http://www.wavesupport.net/Objects/I...V7_macppc.html
Maybe Waves have screwed up here??? :-s
Pro Tools HDX // 11.3.1 HD // 2x Avid 16x16 HD I/O // 2x 192 I/O // Avid Artist Mix
2012 Mac Pro 12-core // 64Gb RAM // macOS 10.12.1
SSL 4056G
Old 11-07-2009, 06:20 AM
Indeed, it is a total contradiction at least, one Waves Tech Spec page states OS 10.5.x is needed on a G5 for Waves version 7, the other Waves Tech Spec page states Pro Tools versions 7.3.1 - 8.01 are compatible with Waves version 7, while only Pro Tools versions 7.4.2 - 8.01 are compatible with OS 10.5.x
Anyway, as I can read in your other thread, you have finally got Pro Tools HD 7.3.1 cs8 on OS 10.4.x working fine on a G5 with Waves Gold version 7. So probably they will also work fine in 7.4.1 on 10.4.x, that's good news!
Marc Schellekens
Old 11-07-2009, 12:00 PM
clusterer clusterer is offline
W.V.7 is workin fine here with PPC G5 dual 2,5 on OSX 10.4.11.
G. Rasek - recording engineer - www.overdub.at - european VO talents via source-connect - PTHD
Old 11-08-2009, 03:37 AM
Ronen Shloosh Ronen Shloosh is offline
Hi There
Waves 7 release supports both Leopard ad snow leopard.
It will work under 10.4.11 however most tests were conducted under 10.5.8 and 10.6.1
If you have a specific issue you can write to Tech-support <Tech-support@waves.com>
Thanks!
Ronen
Old 11-09-2009, 04:42 AM
I did the update from V6 to V7 last weekend, I can confirm Mercury TDM V7 + SSL bundle V7 are working fine om my PPC Dual G5 with OS 10.4.11 and PT HD 7.4.cs10.
The update went fine, no problems with the surrendering of V6 licenses on the iLok, 100 V7 licenses are present now (I don't have TLC versions, so the V6 licenses could be surrendered)
Btw, the only small problem I had after installing the V7 software was I needed to manually delete the V6 waveshells from my plug-in folder
Marc Schellekens
Waves 8 / 9 dual monitor - what a mess! noiseboyuk RTAS & TDM Plug-ins 126 11-15-2014 02:00 PM
Waves and the New Mac Pro with Dual GPUs nhaudio AAX Plug-ins 24 02-17-2014 05:22 AM
using waves 3.5 with dual processors juhadrum 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 08-01-2002 10:23 PM
Waves 3.2 on dual G4--why am I getting errors? Phattlippz Pro Tools TDM Systems (Mac) 4 10-11-2001 07:39 AM
New Dual 800's work, when (if ever) will my Dual 533? Tim R. Pro Tools TDM Systems (Mac) 18 08-28-2001 06:49 AM
