Community Terms of Use
Google Search | Search Knowledge Base | Search Avid.com
Find Support | Pro Tools Support Videos | Support FAQ
Software Updates, Drivers, Manuals, Compatibility, Troubleshooting, etc. (Links)
Please post your message once only to the correct forum
Help us Help You - READ THIS Before Posting!
Pro Tools 11
Go Back   Avid Pro Audio Community > Legacy Products > Mbox, Mbox 2, Digi 001, Digi 002, 003 (Win)
Old 10-28-2009, 10:27 AM
jbroses jbroses is offline
Default MBox 2 drivers
I apologize if this is a dumb question, but after much searching, I've come up with nothing.
My friend bought a used MBox 2 a couple years ago off craigslist. He had it working OK with a PowerMac, but eventually the thing just died. So, I helped him get a new laptop, originally running Vista. He couldn't get his version of Pro Tools (6.something, I think) to work. So he got a version (I think off Craigslist), which is PTLE 8. He couldn't get that to work, either. We then upgraded his laptop to Windows 7.
Basically, he gets a little bit into the installation procedure, and it fails because it can't find drivers for his MBox 2. This should be a simple thing to download off digidesign's website, but I can't find anything for the life of me. Where would I download MBox 2 drivers? It seems like everything should work just fine if the PC could just recognize the device.
I also know he's never updated the MBox 2's firmware, but I don't know if that's an issue.
Any help is very much appreciated!
Jon
Old 10-28-2009, 10:34 AM
LincolnT LincolnT is offline
Default Re: MBox 2 drivers
Jon
If it is the 64 bit version of Windows 7, then it will not work. Digidesign has not made 64 bit drivers yet. Reinstall with a 32 bit operating system.
XP works best. Vista is also supported. 32 bit version of Win7 works, but is not guaranteed.
My reply is true if you are using Pro Tools LE 8. If you are trying PTLE 6.x, then there may be other requirements.
MBox 2 Pro connected to motherboard 4 pin firewire port
Dell Inspiron 9300 laptop
2.0 gHz Pentium M
2 gB ram
Lacie Rugged 5400 rpm firewire 800 on Siig Cardbus adapter
Roland 700SX stage piano
Studio Projects C3 mics
Melodyne Plugin
Dual Boot:
PTLE 8.0.1 on Windows 7 Enterprise 32 bit
PTLE 8.0.1 on XP Media Center SP3
Old 10-28-2009, 11:03 AM
sw rec sw rec is offline
For Vista, you need at LEAST 7.4, earlier versions will not work.
Old 10-28-2009, 01:44 PM
No, it's Win7 x86 (32-bit). And I got it working. It was just ridiculously difficult to find the drivers. Had to do some reboots during the PTLE install, but it worked out.
Here are the drivers, in case anyone else needs to know:
http://www.digidesign.com/index.cfm?...4&itemid=23087
Scroll to the bottom and click "Standalone Windows Audio Drivers v7.4"
You may need to create an account and login.
Old 10-28-2009, 01:49 PM
Also, when using Pro Tools on Windows 7, always start Pro Tools by right clicking on Pro Tools and choosing "run as admin". Some of the features and dialog and settings will be hard to change if you do not run as admin this way. Especially when first setting it up and when first activating plugins.
2.0 gHz Pentium M
2 gB ram
Melodyne Plugin
Dual Boot:
Old 10-28-2009, 02:00 PM
TOM@METRO's Avatar
I'm a little confiused, the Windows stand aone drivers are for the ASIO single client setup and not designed to run Pro Tools 8. If you are trying to install PT8 as you have said, the 7.4 ASIO drivers should not be used.
~ tom thomas
Formerly hobotom
Pro Tools 10.3.5 HDX~HDN
HD Omni +192 I/O
Intel Hexcore i7, SSD
Gigabyte GA-X79-UD3
Reaper 4.32 ReWired
Ampex MM1200 2" 24 trk tape
MOTU 24 I/O W/PCI 424
Outboard, UREI, Eventide, Lexicon, Yamaha, TC Electronics, Orban, ART, EchoAudio, Dolby, Hughes, API, Neve, Audio Arts, BBE, Aphex, Berringer, MOTU, dbx, Allison, etc.
www.metrostudios.com
Old 10-28-2009, 02:03 PM
Hmm... who knows? My buddy installed Win7, popped in the Mbox 2, no response (the lights didn't even come on, or only 1 of 3 lights or something). He installed PTLE8, and it didn't work. Then he downloaded those drivers (7.4 of whatever), rebooted, installed PTLE8 again, and it worked.
I could find NO link to anything other than the v7.4 drivers. Those are just the drivers for the Mbox 2, though, shouldn't work with any version of PTLE, right? PTLE has its own drivers...
I don't know, all I can say is it's definitely working now, and he's psyched.
Old 04-05-2011, 08:37 AM
Questissimo Questissimo is offline
How many monkyes do you need to link a simple driver?
1!
Works great on Win7 64bit.
For Mbox2 Family: Mbox 2 - Mbox 2 Mini - Mbox 2 Pro USB.
http://secure.digidesign.com/service...&localeCode=en
For Mbox2 PRO FIREWIRE: (Thanks DeKKaM for providing this link)
For WinXP Only -------------------> http://archive.digidesign.com/download/audiodrivers/xp/
Old 04-08-2011, 10:44 AM
YYR123's Avatar
YYR123 YYR123 is online now
Exclamation Re: MBox 2 drivers
Questissimo,
Hey did you or can you find the Mbox 2 pro drivers.....
Where did you look?
Thanks in advance.
j.Daniel from Austin Texas
Originally Posted by P,B,S View Post
Now thats a good reminder of how trivial some problems actually are
PT 10.3.2 / Focusrite Liquid Saffire 56 / Better than a Mac PRO (Hackintosh) / i7-3930k / ML10.8.2 / 16GB Ram / AXIOM PRO 49 / BLA PM8
Fender 1969 D-Lux Reverb-1993 Blues D-Lux / Traynor YCV40 / Les Paul 1977 Custom / 1980 Taylor 2010 Taylor 414ce /Behringer V-Amp Pro GTR and Bass V-Amp Pro
/ BFD2 / YAMAHA NS-10M / Springfield XDM-40 to make sure it all stays put !!!
Old 04-08-2011, 05:04 PM
zedhed's Avatar
zedhed zedhed is online now
The link Questissimo provided is for MBox FAMILY
So Pro is included
Happiness is a journey, not a destination.
Need help with Mbox drivers staticdeathnoise Pro Tools 10 Discussion 2 03-03-2013 12:30 AM
Updated Mac Drivers for Mbox, Mbox Pro and Fast Track Ultra now available Avid Technical Alerts 0 10-30-2012 03:24 PM
Mbox Pro 3 drivers jryser Pro Tools Software (Mac) 9 06-29-2012 07:22 PM
Mbox Pro 3 Drivers jryser Pro Tools Software (Mac) 2 12-23-2011 03:25 PM
Please Help! - Mbox 2 drivers? Vasey Pro Tools M-Powered (Mac) 3 04-19-2010 01:53 PM
