Old 09-05-2009, 10:50 AM
luidog luidog is offline
Default ProTools LE 6.4 Download for Digi 001
I've spent the last 2 hours trying to get LE 6.4. I recently bought a Digi 001 off of ebay and need 6.4.
I've tried using the digidesign site and have found the download link @:
http://www.digidesign.com/index.cfm?...54&itemid=4959
The link at the bottom "Pro Tools LE 6.4 for Windows XP"
I'm then asked for my, "Authorization Code" which I don't have. I go to, "Lost LE Auth Code?" on the right and it takes me to MyDigi, where at first I had no Auth Codes, I then looked up my 6.* code and now I have one beginning with, "DIGI0600." But when I input the code given to me I get, "Warning: Software code specified is invalid "
Any ideas? I tried searching the forum but with no luck.
Old 09-05-2009, 11:26 AM
Avid's Avatar
Avid Avid is offline
Administrator
Default Re: ProTools LE 6.4 Download for Digi 001
Found the problem, check your email.
Administrator
Old 09-15-2009, 08:03 PM
soav soav is offline
Hi All,
I encountered the same issue as 'luiDog'. I just purcahsed an 'used' Digi 001 with controller card from the internet and was given the Protools 6.4LE software for both Mac & PC(burned cd-r) but unfortunately, after installed it on my mac, an 'Authorization Code' is prompted to me to enter before i can use the Protools 6.4.
I tried check with the previous owner but was told that he had lost the codes & others.
Kindly anyone can help me ? Many thanks in advance!
Cheers.
Old 10-04-2009, 02:41 PM
luke_violin luke_violin is offline
Hi.
I've got this same problem.
Do you know, maybe, how to fix it?
Old 03-28-2010, 03:56 PM
monkfink monkfink is offline
Red face Re: ProTools LE 6.4 Download for Digi 001
I'm in virtually exactly the same scenario.
Bought a Digi 001 off of ebay and need 6.4.
I'm then asked for my, "Authorization Code" but my 5.3.1 code is not valid.
Do i really have to go bac to SP1?
Any ideas? Any help really appreciated.
Old 03-28-2010, 04:35 PM
sunburst79 sunburst79 is offline
SP2 and SP3 should be fine. I'm on SP3
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 03-28-2010, 07:31 PM
John_Toolbox's Avatar
John_Toolbox John_Toolbox is offline
Your 5.3 auth code will not authorize 6.4. A 6.x install code will start with DIGI06... your PT 5.3 code will start with DIGI0531.... They are unique codes designed only to unlock a specific software version. Since PT 6 was a paid upgrade from version 5, it will require a different authorization code. If you didn't get a code with your 6.4 installer you can buy one from digidesign, last time I bought one for 6.4 it was about $35 so they're relatively cheap.
- John
If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound?
Old 02-22-2011, 01:25 PM
studio1176 studio1176 is offline
Hey folks,
I'm also in a similar position.. I lost my authorization code in a fire and now I cannot install my software.
This is for an old iMac G4 with and Mbox with PT 6.2.2
I bought the mbox used several years ago, so I'm lost as to how to acquire an authorization code without spending more money.
can anyone help?
thanks!
Darcy
studio1176@hotmail.com
Old 02-22-2011, 07:41 PM
If it's registered in your name the auth code should be available in your avid account.
Old 03-25-2011, 11:42 AM
EDF EDF is offline
None of these devices would be in our names.
What should I do?
HTML code is On
Protools LE 8.0.5.1 download Matt Darcy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-13-2013 04:37 AM
No way to download Protools R3dlight Eleven Rack 5 12-22-2012 02:03 PM
if i download protools,can i inocybesang 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-23-2008 08:42 PM
download protools? spy2520 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-08-2007 03:58 PM
Protools 6.7 Download OSX TonySe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-13-2006 02:41 AM
