Old 08-24-2009, 07:59 AM
buckaroo buckaroo is offline
Default Digi 96io - can you mix Optical SPDIF and phono SPDIF?
I have a 96io which I would like to input an optical spdif from another mac, and also use the phono spdif input from a PC soundcard
I am setting up the DIGI coreAudio manager, but it seems you can only have one or the other?
Is there any way to get both SPDIF inputs working and naming a channel for each ie:
Input :
1-2 Analog 1-2
3-4 S/PDIF [enc]
5-6 Analog 5-6
7-8 Opt (S.PDIF)
Is this possible???
Old 08-24-2009, 12:20 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Digi 96io - can you mix Optical SPDIF and phono SPDIF?
its one or the other as there is no optional digital board like the 192. and the optical i/o can only be adat once s/pdif or AES is selected in the hardware setup.
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
ProFire 2626: SPDIF COAX & SPDIF OPTICAL Simultaneous success!!! WHAAAA HAPPENED??? cueball73 macOS 0 05-22-2012 01:41 PM
Spdif RCA to Spdif Optical conversion - degradation?? Hollow Body 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-17-2011 09:21 AM
Optical SPDIF Digi 002 nino5000 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-22-2007 11:24 AM
spdif to optical converter and using opt and spdif Hollow Body 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-09-2006 06:41 PM
Echo Mia W/ SPDIF also does RCA style SPDIF cause the same crashes as optical?? Paul_m 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-16-2003 06:41 AM
