Old 08-11-2009, 06:28 AM
crizdee's Avatar
crizdee crizdee is offline
Default NI komplete kontakt library location?
The installer for NI Komplete SNAFU and even with the Leopard installer patch it won't install the library disks (well it doesn't give the option to select the location to save the files, its just tries to install on the system drive and says finished after 30 seconds)
So i'm going to have to copy them manually into the right location. i have a folder for the library and each instrument has its own folder! but i don't know where exactly the library should install? if it has its own folder inside the Kontakt folder or inside the presets folder are wherever.
So if someone can tell me exactly where the library resides in the kontakt folder and the folder name etc!!
Been at this for 3 hours already
This might just be the biggest mistake of my life
Chris
Producer, Engineer,
UKmastering E-Mixing & Mastering facility
www.ukmastering.com
PT10.3.7 Lion HD6 accel Magma PE6R4 Control 24 Harpertown 8-core UAD-2 Quad / SSL Duende Native. Manley Vari-Mu, Manley Massive Passive, Solid State Logic VHD, Anthony De Mario ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 08-11-2009, 06:48 AM
tonwurm's Avatar
tonwurm tonwurm is offline
Default Re: NI komplete kontakt library location?
I´ve installed the Kontakt Library on an external volume in a folder "Kontakt Library"
in Kontakt you can choose which files are searched at startup ("options"-menu right near the disk-icon in the upper plugin-window), there you can drag your library-folder and also other folders you want to use (f.e. exs24 library...)
then make a database rebuild (in the upper left plugin window under "Database", that will last a while), so that Kontakt knows where all the samples reside
Mac Pro - PT10 HD3, PT12 HD, Logic X, DP 7, VEPro, OSX 10.9.5
MacBook Pro - Logic X, Mainstage
www.perfectzeromusic.de
Old 08-11-2009, 08:24 AM
crizdee's Avatar
Thanks, i think i'm slowly getting there! each disk is taking 30-40 minutes better be worth it
I've never tried Kontakt, and structure is tooooooo slow to browse the library! see be interesting to try it.
Chris
Producer, Engineer,
www.ukmastering.com
Old 08-11-2009, 08:31 AM
tonwurm's Avatar
I´ve working with it since years within logic and there it has always worked quite good
in PT since Kontakt 3.5 it works good, too - at least with my system, performance has become better, too
it´s a mighty peace of software - and imports nearly everything, f.e. my exs24 library and my old SampleCell library without any problems
hope it will work for you !!
Old 08-11-2009, 08:36 AM
relaxo relaxo is offline
I work with all of my samples, including Komplete 5, on a separate drive from my boot drive, which is backed-up with Time Machine. That way, my boot drive is as small as possible, so if the boot blows, i can restore from Time Machine in 1.5 hours. My new boot will be IDENTICAL in every way. (It works. I just had a Mac Mini drive die. T.M. worked as claimed.) I have T.M. on six Macs. Keeping samples on a separate drives also makes clean system instals and DAW rebuilding a lot quicker, especially if your samples collection is 100GB+ and especially 1TB+.
Old 08-11-2009, 08:54 AM
crizdee's Avatar
Just one more question about the library!
Disks 5/6/7/8 have some of the piano samples on and again the installers are stuffed so i have to copy manually to the drive. do these samples folders just go into the Akoustic Piano folder?
Chris
Producer, Engineer,
www.ukmastering.com
Old 08-11-2009, 09:11 AM
Scott Goldberg Scott Goldberg is offline
Chris,
They should go into their own folders by default. You'll like it a lot. It works great for me.
Scotty
Scott Goldberg
Gold Recordings
http://www.goldrecordings.com
Old 08-11-2009, 11:22 AM
crizdee's Avatar
Yes they should
But the Leopard patch fixer didn't work on the disks 3/4/5/6/7/8 so i'm having to copy everything manually.
one disk wont even show on my Mac, i'm having to load it on my PC then copy it over!
Chris, eek eek nyuk nyuk nyuk
Producer, Engineer,
www.ukmastering.com
Old 08-11-2009, 02:31 PM
crizdee's Avatar
Well, 9 hours of struggling to get all the DVD's to install and authorized
The installer is absolute xxxx a total joke.
Akoustik piano is missing all files
Battery is missing all files
Battery makes PT freeze and i have to force quit
And yes i have downloaded all latest versions using service centre
Producer, Engineer,
www.ukmastering.com
Old 08-11-2009, 02:41 PM
go to very top of battery window and select "options" under the "file" button
set the final folder in the "factory content path" to "Battery 3 Library"
same sort of procedure with Akoustik piani I think
where is the User library default location bear0328 Pro Tools 11 4 05-01-2014 01:19 PM
Komplete 8/Kontakt 5, plus more officially announced! nst7 Virtual Instruments 3 08-19-2011 12:42 PM
Structure Library Location jbr Virtual Instruments 2 08-27-2010 01:18 AM
structure LE library location Mr.O Virtual Instruments 3 09-06-2009 02:19 PM
Best sample library location? RpwBass Digidesign Hardware & Software 6 01-10-2002 08:15 AM
