Old 08-10-2009, 10:45 AM
dmf dmf is offline
Default LE 7.3 boot problem
hi,i seem to be having an issue with 7.3 not booting,everything is fine after i install it for a day or two then suddenly it wont boot and it freezes the desktop.any ideas? im on xp and sp3.thanks.
Old 08-10-2009, 10:47 AM
spkguitar's Avatar
Default Re: LE 7.3 boot problem
Did you install Internet Explorer 8?
Please read this technical alert from Digidesign/Avid.
Old 08-10-2009, 03:11 PM
dmf dmf is offline
ah! that's what messed it up,thanyou.....always something simple.
anyone any idea why when i boot pro tools it is unable to find the hardware???everything is connected and software etc fine.
Old 08-10-2009, 03:15 PM
sw rec sw rec is offline
That problem has seemed to follow the IE8 install/uninstall problem. Perhaps an un-install/re-install of Pro Tools now that IE 8 is out of the way? (I know, what a pain!!!)
Old 08-10-2009, 04:27 PM
jazzmandan jazzmandan is offline
",,un-install/re-install of Pro Tools "
Keep in mind that this is trickier then it sounds. It is like a cavity in a tooth, if you don't get it all out, the tooth just continue to be a problem.
There is a removal tools available to get it un-installed good!!
Good Luck from one who has been there.
~2004 - Dell 4600 P4 3.0GHz, 2.0 GB Ram, XP Home SP3, 80GB HD for System, 120GB HD for Audio BIAB 2009, Pro Tools 8.0, MBox
09/12/2009 - Dell XPS 435T/9000 i7, 6G Ram, Vista 64 Bit 750 G SATA for System, 1TB SATA for Audio, Protools 8.0.1, MBox
10/31/2009 - Win 7 64Bit
MBox /PT not supported under Win7 - I didn't leave PT, PT left me!
11/30/2009 - MBox, REAPER
http://www.jazzmandan.com
Old 08-11-2009, 08:44 AM
dmf dmf is offline
thanks guys...
tried reinstalling etc and no joy....is it a matter of retrying??or where might be the emoval tools be found?.
by the way if I.E.8 is no good is any of the other browsers compatible?
Old 08-11-2009, 12:54 PM
Firefox
Old 08-12-2009, 05:50 AM
dmf dmf is offline
still no joy connecting to pro tools/hardware issue even after wiping and reintalling windows etc,everything is totally connected.what the heck would be the prob?
Old 08-14-2009, 06:58 AM
dmf dmf is offline
can someone off some help as im stumped this time!
ive tried all the usual tricks,disconnecting the firewire cables,removing the adapter,disconnecting the oo2 cables inside etc.......could it be a faulty firewire adapter?the pc doesnt make the connection sound or tell me its connected and only the odd time makes the sound when disconnected.....the light on the oo2 says they are connected.could it stillll be a IE8 prob even after i have reinstalled windows?!!
Old 08-14-2009, 07:09 AM
spkguitar's Avatar
Are you "hot swapping" the firewire connection to the 002? Plugging it in while both the computer and the 002 are turned on?
If so, you are not supposed to do that! You can, and may have fried the firewire connector inside the 002 by doing that.
Mac Pro/HD3 boot-up problem Futurist Pro Tools TDM Systems (Mac) 206 05-21-2011 08:07 AM
g5 boot problem... usd Pro Tools TDM Systems (Mac) 12 02-18-2009 12:34 PM
Boot Problem with OS9 UTS Pro Tools TDM Systems (Mac) 5 01-15-2005 09:55 AM
A7N8X PC with a boot up problem! iceblueD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 12-30-2004 09:40 AM
OSX Boot problem Reckless Erik Pro Tools TDM Systems (Mac) 0 09-24-2003 02:40 AM
