Old 08-01-2009, 10:17 PM
ntime ntime is offline
Default Track 1 & 3 problem
If anyone has any suggestions, I could use the help. The 003 workstation will not record condenser mics on input tracks 1 & 3. However, it will record dynamic mics and direct line sources. The phantom power works fine on tracks 2 & 4 which is odd because 48v phantom power is paired 1 - 2 and 3 - 4.
Old 08-01-2009, 10:22 PM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Default Re: Track 1 & 3 problem
Yeah that is odd... Welcpme to the DUC... OK so u are connecting ur mic(XLR cable) directly into 1 or 3 & making sure the MIC button is pressed & giving it gain, etc. rite???
Too, u r setting the input in PT on the correct input as well???
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 08-01-2009, 10:32 PM
I connect a MXL condenser microphone each one of the 4 inputs with the following settings: phantom power switch pushed in, Mic/Di switch selected for Mic, and the trim level set 3/4's of the way up. I get a signal on analog 1 & 3 but not 2 & 4.
Old 08-01-2009, 10:41 PM
Is this a new unit? That really is ODD(no pun intended)
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
Old 08-01-2009, 10:50 PM
It's practically a new unit. I purchased the unit about a year ago but did not get a lot of record time on it. I recently set it up in my office and have been testing the in and outs of it when I noticed this weird problem. I am hoping it's just a setting that I am overlooking. So far, I haven't found any software settings or hardware settings that looks out of place.
I appreciate your quick response.
Thank you!
Old 08-01-2009, 10:56 PM
No prob...Yeah as for hard/software out of place I don't think thatz the case... I think u may just have a bad unit... If ur using the exact same XLR cable into each input for testing with the same settings & gettin different results in that manor then thatz a prob...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
Old 08-01-2009, 11:04 PM
The last time I recorded with it I don't remember complaining about this sort of problem. Especially, since I usually test the ins and outs before I start a session. Shame on me if I let a problem like this get past me earlier.
I guess I am going to have to sleep on it and hope for better results later.
Thanks again.
Old 08-02-2009, 01:36 AM
flommer flommer is offline
Yeah, make sure you test your cables too.. stranger things have happened..
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 08-02-2009, 04:29 AM
tamasdragon tamasdragon is offline
Try to go through 1-4 with the same cable, which worked in input1.
And doublecheck your internal routing, it's easy to click to a bus, or adat, or anything else.
If really nothing works, it must be your unit.
Tamas Dragon
my blog:Tamas Dragon
Old 08-02-2009, 05:56 AM
Oddbod Oddbod is offline
I agree with tamasdragon & flommer. Cables are so important and often the forgotten link in the chain.
O-B
ADC and AUX TRACK - BIG PROBLEM Siddhant Bhatia Pro Tools HDX & HD Native Systems (Mac) 2 05-15-2011 09:33 AM
Problem bussing audio from one track to another audio track harryk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 08-04-2010 01:15 PM
Problem Converting Instrument Track to Audio Track Gorbies 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 06-02-2009 10:11 PM
can't pan track problem ? jackp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-22-2008 10:34 PM
Problem With Last Track elik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-14-2002 12:35 PM
