Old 07-20-2009, 11:01 AM
dj_grimmace dj_grimmace is offline
Default PT Stuck in Prime for Playback mode
This is happening on an LE system using PT 8cs3 and a Mac Pro 8 core. I posted this in the LE forum but didn't get any responses so I thought I'd try here...
Every once in a while, Pro Tools seems to be getting stuck in Prime for Playback mode. The result is that I can't actually playback the session at all. I can fix this by trashing preferences, but the problem comes back.
Unfortunately, I can't find a way to predictably repro the problem. Has anybody else encountered this?
Is it possible that this is a feature that I'm unknowingly instantiating?
Any help would be appreciated,
Matt
Old 07-20-2009, 11:24 AM
ajv205 ajv205 is offline
Default Re: PT Stuck in Prime for Playback mode
its a bug. restart protools.
Old 07-20-2009, 11:54 AM
Unfortunately, restarting Pro Tools doesn't fix the problem. Furthermore, it is session specific. If the bug occurs in one particular session, it will consistently occur ONLY in that session until I delete preferences/volumes.
If I open a different session, playback occurs as expected.
Old 07-20-2009, 01:59 PM
midnightrambler midnightrambler is offline
Corrupt session? I've had a few of them over the years. Had to import a track at a time to a new session 'til I found the culprit.
Old 07-20-2009, 07:29 PM
If this just happened in one session, or more infrequently I'd say yes. But it keeps happening. I think ajv205 is right, it's a bug, I'll send it in to digi.
Old 07-20-2009, 08:46 PM
Craig F Craig F is offline
you try trashing the prefs?
Thank you,
Craig
Old 07-21-2009, 11:33 AM
If you read just a little farther up the thread my friend, you will see I have . This temporarily fixes the problem, but it recurs in subsequent sessions.
Old 11-23-2012, 08:04 AM
ct2222 ct2222 is offline
HOW DO YOU FIX THIS PROBLEM ? Does anybody know the answer? Please answer
Prime for Playback/Record keyboard shortcut problem David Hardie macOS 1 10-21-2012 05:47 AM
PT stuck in Prime for Playback mode dj_grimmace 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-19-2009 09:13 PM
7.1 Gets Stuck in Scrub Mode deanguidry 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-12-2008 09:54 AM
Stuck in PIO mode. stevegrisham 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-27-2004 02:43 PM
USD is stuck in Generate Mode!!!! Help!!! pnoise Pro Tools TDM Systems (Mac) 2 09-17-2002 01:28 PM
