Old 06-27-2009, 01:04 PM
macfreak86 macfreak86 is offline
Default can't record enable a track
I'm trying to record in protools and i'm getting this error message:
this track could not be record-enabled because it does not have both an active input and output assigned.
i'm using ptle 8 with a digi 003 rack on a mac pro 1st gen.
Old 06-27-2009, 03:48 PM
Default Re: can't record enable a track
You need to assign a working input and output for the track. The output is usually your main l&r. The input would be whatever input you wish to record(a single input for a mono track and a pair for a stereo track. Check the manual on I/O setup as there's a lot of info that can help streamline your work flow.
Asus x99, Intel i7 6800K, 32 gig DDR4, GeForce 750 Ti, HD/Native, HD IOx2, PT11HD, UAD Quad, preamps from Vintech, Five Fish Audio, Miktek, Focusrite, Chameleon Labs and Midas..............................
www.capricornsoundworks.com
Old 07-11-2011, 05:11 PM
brandobean brandobean is offline
I got this error too and was totally confused. The problemw as that it LOOKED like an output was correctly assigned (to output = Main out) but because I had powered ProTools on once with my interface off, all those inputs were inactive. All I had to do was re-select them in the I/O section and they changed from dimmed out italic, to active.
Confusing I know... it looks like your inputs are set up correctly. But they are inactive.. until you re choose them again
PT 10 Audio track will not record enable brethart Pro Tools 10 3 06-25-2013 05:58 AM
Cant record enable more than one track at a time Aikoaiko 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 02-19-2012 02:55 PM
When I enable a track to record and then hit 'play' the track will remain silent Rainerbird Pro Tools M-Powered (Win) 2 08-07-2009 09:41 PM
Track Record Enable KC mattrixx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-26-2009 06:58 AM
Can't record enable track in DP 3 clockface 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-29-2003 11:05 AM
