Old 06-20-2009, 10:35 AM
AdenP AdenP is offline
Default Mbox 2 as Primary Sound Card?
I've done a bit of looking around, and some people's similar problems have been solved, but they don't help me.
I'm running Vista 32bit, and I want to know if its possible to have the Mbox work as my primary soundcard.
In other words, it all works fine with Pro Tools, but any other general computer sounds and audio that is not played through Pro Tools (i.e. Windows Media Player, Youtube, Myspace etc.) just try to play through the normal (crappy) soundcard in my computer.
I've tried
Control panel > Hardware and Sound > Manage Audio Devices but no option appears for my Mbox.
Any help would be really great, thanks a lot.
Aden
Old 06-20-2009, 11:10 AM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Mbox 2 as Primary Sound Card?
In one word: No.
There is no WaveDriver "yet" for Vista. It's supposed to be in the pipeline, but I fear it is very far up that pipeline, in fact, so far it may not be visible. An ASIO compliant program, IIRC WinAmp has an ASIO plug-in, will use the Mbox as a soundcard.
Even if there was a WaveDriver for Vista, at the moment, Digidesign hardware is single client, so you could not have more than one program using the Mbox at the same time.
Cheers,
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 06-20-2009, 11:21 AM
Ah ok. Thanks for that, at least I won't waste my time trying to sort something out that is un-sortable.
Shame. Nevermind...
Old 10-14-2009, 10:09 PM
markyrokz markyrokz is offline
what about on a mac?
Old 10-15-2009, 07:17 AM
sw rec sw rec is offline
Best bet is use your on-board sound for all other audio. There's a whole lot of us on here doing just that and it works like a charm.
Can't help ya with the MAC option, though. Maybe post it on the MAC forum and see how that's working out. But I SUSPECT the answer will be the same.
Mbox 2 Pro As Primary Sound Card?!? thetoy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 08-10-2009 02:17 PM
002r as primary sound card barznbeats1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-02-2008 09:40 PM
using 002r as a primary sound card? revolver 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-26-2004 08:49 PM
how can i set the mbox as primary sound card? starrackerman1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 04-25-2003 12:37 AM
how can i set mbox as primary sound card? starrackerman1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-24-2003 12:39 AM
